V6 vs I6
28 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
just curious which engine people prefer. each one has its pro's and con's; V6 is more compact, I6 has better harmonics yadda yadda yadda. now im not saying that i know more about engines than those clever people at nissan, but perhaps if we got enough votes for the inline engine then nissan would consider making the good old RB again?
https://www.sau.com.au/forums/topic/330940-v6-vs-i6/
I don't think Nissan would remake the RB ever again. It will never meet emissions. The trend now is all alloy and larger displacement engines - reason being is for balance, cost and emissions - something to do with thermo dynamics.....
The RB is from the mid 80s.
however... It would be interesting if Nissan does sell its patents for the RB to 3rd manufacturers for developing countries....
https://www.sau.com.au/forums/topic/330940-v6-vs-i6/#findComment-5374728
agreed
cars these daysr gettin0g bigger/heavier with clever electronic
v engine allows bigger capacity in more compact package to allow more space in engine bay to fit other stuff while allowing better placement for weight distribution
with nissan's future vision dun think they'll go back to inline6.
even bmw uses v config in their current M3 now...
https://www.sau.com.au/forums/topic/330940-v6-vs-i6/#findComment-5375218
The VQ engine design dates back to 1994, so hardly more refined emission's wise, and nearly any engine can be made emission friendly, personally i think the RB engine feels a lot more refined.
Its kind of annoying that Nissan had to throw the cooking version of the v engine into the 350Z and 350GT rather than develop it a little more like the VR/HR engines, having come back to Nissan from Toyota, i must admit to being rather disappointed, i had a Supra and for a 17 year old design and manufacture, the quality and build just takes the piss from Nissan.
https://www.sau.com.au/forums/topic/330940-v6-vs-i6/#findComment-5375385
Perhaps you need to try all the VQ variants out, VQ25det is the pick imo, in stock form at least.
They are all strangled by electronics and open up with a tune but they will respond beautifully to forced induction. I have an unopened VQ25det in my Stagea running 260ish awkw with no issues. Torque is up around 650nm so it gets the barge going quite well.
Emission's wise, its better than a prius as I have been running E85 for months. :)
https://www.sau.com.au/forums/topic/330940-v6-vs-i6/#findComment-5378754
I'm going to have to pick V6 as well, it's geting very hard for manufacturers to get I6 powered cars through frontal impact standards these days as they have the nasty habit of entering the passenger compartment.... like a battering ram, where as the VQ motors have an 'engine drop' function in case of a frontal impact, it effectively ejects the motor out the bottom.
If we're still lusting after an updated RB series then I wouldn't count on it, the RB is an old fashioned motor, it makes good power because it was built like a brick dunny, so could withstand monumental amounts of boost pressure. More boost, more fuel more power. As a result the motor weighed more than a small block chev and was thirsty as hell even in NA form.
Modern engines have to use a lot more finesse and technology to achieve power, combustion chambers these days are much more efficient, so you get more bang for less fuel. The VQ35 for example weighs as much as a 2L 4 banger from the 80's but makes 230Kw in HR form.
V6 is the future I'm affraid.
https://www.sau.com.au/forums/topic/330940-v6-vs-i6/#findComment-5382946
With the technology currently in the VQ motors, i have no idea why you would ever want to go back to something so ancient as the RB. (in comparison)
Nissan's current V series motors are amongst the best in the world.
Exhibit a
VQ37VHR
A rocker arm and two types of links open the intake-valves by transferring the rotational movement of a drive shaft with an eccentric cam to the output cam. The movement of the output cam is varied by rotating the control shaft within the DC motor and changing the fulcrums of the links. This makes a continuous adjustment of the valve lift amount possible. C-VTC and VVEL together control the valve phases and its valve events, allowing free-control of the valve timing and lift. This results in more efficient airflow to the cylinder, significantly improved responsiveness, optimizing the balance between power and environmental performance.
Yes the RB is a great motor , and will always be special amongst many motoring fans, Nissan fans or not, but in my opinion the newer range of V motors win hands down.
I think if emition laws weren't so strict and Nissan could freely strap a couple of, or a single turbo to the VQ's, then I'd guess that most of us would be saying RB-What?
https://www.sau.com.au/forums/topic/330940-v6-vs-i6/#findComment-5384369
agreed
Yeah but thats a V8 right...Whole different ballpark there...
https://www.sau.com.au/forums/topic/330940-v6-vs-i6/#findComment-5384564
VQ25det
VQ30det
Both great engines with no aftermarket support.
What gearbox would handle the sort of power a vq37vhr twin turbo would put out though? 20psi on the stock motor running E85 would be interesting to say the least.
https://www.sau.com.au/forums/topic/330940-v6-vs-i6/#findComment-5384764
I hope you mean a V6 is better in terms of weight balance in a car and not balance as in mechanically. Mechanically it is shit in comparison to an I6, the I6 is arguably the best configuration in terms of dynamic balance of rotating components. Interesting to note that Fords I6 4.0L is being updated to meet new emission laws (last I heard).
https://www.sau.com.au/forums/topic/330940-v6-vs-i6/#findComment-5384836
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
