  • Replies 62
Posted Images
are the walbros a direct factory replacement? where can you get a genuine one from? be interesting to see how they compare price wise with the bosch 040s for those of us with stockish rb25dets
As long as you get one specific to your car it'll be a straight swap. I've done 2x32 Gts-t's, 1x32 GT-R, and 1xLegnum with no issues.
You can get them at any good performance shop, or eBay. Beware on eBay though as some mobs are selling the knockoffs as genuine Walbro.
Mine was legit, 6 years ago before all these fakes appeared on the market 270rwkw, that was show over for my Walbro.
13:1 AFR's. Bosch pump change over, 10:1
So now the Walbro just gets used as a lift pump for my surge tank.
The issue with Walbros is pressure, they are FINE for N/A power applications - as boost climbs, so does pressure, flow rate then drops off.
There are graphs around here and on the net of the various comparo's.
If you intend on running more than 240rwkw and 15psi - get a bosch or a similar jap/other more suited pump.
Otherwise just for the above the Walbro item is a cheap and good solution.
Sorry but that is just total bullshit... We ran 29psi through my car not more than a month ago making over 270rwkw with 11.5 afrs with no fuel issues.
We also have run 20psi through a Supra last year making 330rwkw with no fuel issues!!!
You are duly misinformed!
How many of you people have removed your tank to clean it when changing a pump? Walbro or Bosch....if you didn't have the tank cleaned, then you cannot make fair comment on either one failing.
I have always, and always will judge them on flow rate
At 60psi the flow rate drops to 50 gallons per hour which is 189L/hr. The standard fuel pump is virtually the same. The Bosch intank pumps flow 200 L/hr at 70psi. At 60psi they are still doing approx 230L/hr.
Anyone running 15-20psi of boost will see rail pressures of around 60psi
Since when goes a Skyline pump run on 12V, get a clue and rewire your pump correctly and you will get 13.8V of constant power... This means according to your graph you will get 60 gallons per hour which is 227L per hour!
You do realise that 227L per hour times by 1000 to make cc divided by 60 to get min and then divided by 6 injectors of a RB = enough fuel to flow over 600cc injectors CONSTANTLY
My question is how much power can you make from 600cc injectors?!?
Even 189L per hour at 12V is enough to feed 500cc injectors...
Edited by SimonR32
Get a clue?
You need to calm the f**k down asshole
  • 2 months later...
I think I'll be needing to uprate the GTR one sat in my 33gtst - I'm aiming for 370kw (500bhp) so hoping a tomei or nismo one will help me get there - would rather pay the pennies altho that said dont these guys just basically rebadge a bosch044 or bosch 040 or something?
To the guys using walbro pumps with big power and big injectors. I'll bet my left nut that duty cycle or Injector opening time is way more that what it needs to be,
Ive been doing some research on this and if you have injectors big enough you can make big power with a walbro but the injectors are open for a lot longer than what they need to be, and the fuel basicly just dribbles out, causing bad atomisation etc etc,
I has seen similar things to ash, where cars have had 750cc injectors and ~280-300rwkws and the injectors are approaching between 70-80% duty cycle when they really should be just ticking over.
Same guys added 2x 044s and screwed some fuel pressure in to it (single hole injectors with a less than ideal spray pattern) injector duty went back to 50% and the car no longer belched out tonnes of black smoke due to the better burn in the chambers from having better fuel atomisation.
Holy epic post for 9am Saturday lol
just thought I'd add I fitted my walbro nearly 3 years ago. the car is making 350rwkw's without issue. the only reason I'm going to upgrade is for future plans to run the fruit juice
Which model walbro Gss-341 or Gss-342?
I'm running a walbro, making somewhere in the vicinity of 270+ rwkw I've yet to do the hard wire (will be done in the next week or 2) and running seimens deka 550cc injectors... The highest duty cycle I've seen according to nistune so far is about 40%
Where's a good place to buy a bosch 040 from? Are they genuine ones on ebay? cheers
Autobarn. A bit exxy (bout 50 bucks more or so), but you get it same day, wham, bam thankyou ma'am. When i blew my pump on a skidpan, i simply got a lift with a mate to autobarn. Bought it, and within 40min i was back on the pan =)
get on the yank car forums for most models and even the biggest budget buildups are using 2 or 3 or even 4 walbro setups, they seem to think they are fine and making big power. Ive never read a bad word about them on those forums and its the most common used pump for those platforms. Ive seen in person one pump make 440rwhp on a 3l turbo engine without drama and still going strong 4+ years later.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
