After putting the Nismo pads on, the brake dust on the front wheels are just ridiculous (someone told me it might be just bedding in to the rotors). Having white rims doesnt help so... I'm thinking of powder-coating my LMGT4 to black but I'd like to retain the genuine Rays' sticker on them. Is that possible? I know powder coating is around 80-100 per rim? But the sand blasting would rip the shit out of the stickers...
Or maybe someone knows somebody that wanna swap a set of black TE37/LMGT4 in 18s with me? Recommendations for powder coating shops around Brisbane or advices are all welcomed. Cheers.
PS: I'm not concern over the Nismo sticker because they can be replaced.
https://www.sau.com.au/forums/topic/331021-powder-coating-rims-retain-stickers/
May be able to heat the stickers then lift them off and somehow apply them again?? Would be a very fragile and difficult job, but that's the only way i can see if you want to retain the originals.
Nah I'll just live with it if it cant be done (which I sort know but just wanna confirm).
Seems highly unlikely. And pointless.
Its not pointless. This is not the Nismo sticker on the spokes but the manufacturer's sticker with details of the rims on the inside. Thats the easiest way to tell if the rims are genuine Rays.
you do realise powdercoating is baked in an oven, and the rim must be sandblasted beforehand. just find new stickers. a place at sumner park does them 65 a rim minus sandlbasting charge.
Yes I do. Thanks for the recommendation too.
:):D :D
Take one of your wheels off and look at the back between the lugs. They'll be stamped if they're genuine. If it was as simple as putting stickers on it there would be a hell of a lot of copies out there already posing as fakes...
Actually... if yours only have stickers and no stamps... :D
It'll look like this if they're real
and if they're fake then you don't need to worry about stickers :D
Edited by Isola
Did I not say the easiest? You'll have to pull the wheels out to see that stamp whereas the sticker is visible without doing anything.
1 thing man -
Doesn't the sticker/markings whatever, only mean something upon the sale of the rims? - like to prove to the buyer that they are legit..
I'm not buying any rims that i cant take off the car before I pay..
go to the joint Dave recommended :)
OR buy some rota GTR-D 18*12s in black :D
:D Fancy some cheese?
You're wrong anyway. The easiest way to tell if they're genuine is to LOOK AT THE STAMP. Looking at the sticker is just the easiest way to see if it has a sticker on it. Anyone can make up a sticker and bang it on. I could sew an Armani label inside my jacket, but it still won't be one. Get it?
The car is 8 inches off the ground anyway - turn the wheel and use a torch or a torch and mirror if you have to.But really, if you can't have a wheel off and back on again in 5 minutes there's something terribly wrong.
:) Fancy some cheese?
And there is nothing wrong with that!
Can said place also straighten wheels and repair gutter rash ?
  • 2 months later...
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
