  • Replies 80
No, Jess. Unfortunately, I was unable to make it this year.
I am sure that Mark will be back soon bigger and better.
Aww It would of been really nice to see you! Been ages! :wub:
I hope so! :blush:
stop talking shit about a brother when you tossa's dont know shit!!! mark has never done wrong by any one and if any kunt says that he has then tell them to come see me!!! if you aint got anything nice to say about a brother then get f*ked!! go suck on your mummys dick for a bit might easy the pain! f*kn keyboard worriers!!
Edited by hashish_dla
OK enough of that. Any more carry on will receive a warning.
Mark, sorry to see what happened, would have been great to see 2 leading skylines runs together. But as they say, "that's racing"..... I guess new shell will be easier than fixing since it is all triple skin back there, and shells are cheap.
x100, sorry to see. I saw the car running on saturday when I was down toward the end, and my oh my, she looked the goods ;)
I guess you an at least be thankful you managed to keep the front end off the wall, would have been a total disaster if she copped that hit in the nose!
thanks for the support guys...we have looked at the data and the front wheels were off the ground in first and 2nd gear hence the sharp turn to the left when the tyre landed...4wd is a nightmare...
car will be fixed in 2 to 3 weeks.. rear damadge is easy to fix...if it would have hit the front the car would have been a complete mess..right off..
our next event is on the 18th of sept at willowbank pro street shootout...we will be back ..
with all the data from the weekend we are very happy...except for the crash..ha ha
cheers, mark
Mark - great to hear your ok and the car isnt damaged to badly. It looked rather nasty, and sounded that way as well, but as you say rear damage is an easy repair in the right hands
I guess i may be sarting a rumor but i am sure i over heard one of the HTL team talking about leaving the car here and testing in Sydney.... would be awesome to see these 2 cars go head to head at some point in time soon :thumbsup:
I guess i may be sarting a rumor but i am sure i over heard one of the HTL team talking about leaving the car here and testing in Sydney.... would be awesome to see these 2 cars go head to head at some point in time soon :D
Yeah its definitely staying, its over there to set the world record lower - that hasn't happened yet ;)
Also I believe they want to throw some street tyres on for lols and see if they can "adjust" that record as well while they have far stickier tracks to play with.
just got the log out of the car now...wheelspin and over rpm in 1st gear were the cause ...2nd gear went straight to 10500rpm on the shift... the axles are fine...
which basically means no slip in the clutch at all ..which softens the way the car gets down the track...
1.6 g impact into the wall at 50mph...oops..
car is being fixed this weekend should be finished next friday....
keep you guys posted...
Cool!
If there's any chance of advance notice of when it's going to be running some of us SAU guys could come up and watch :P
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
    • WRXs are a pure pleb boring car these days. You need to get an STI to even get close to what a WRX used to be.
