Depends on what you really want to spend. NIStune's are around $250 or so, whilst Power FC's around the $800-$1000
NIStune, is just a motherboard, which allows your stock ecu to become completely programmable.
Power FC's are a whole new computer, with hand controller, so you can do 'on-the-spot' programming.
NIStune's are not legal, and neither are Power FC's, advantage of NIStune would be that it is virtually impossible to detect from a coppers point of view, apart from the USB port that is made to allow the USB cable to plug into the laptop to tune,whilst a Power FC is recognisable from its Apex'i casing. Hand Controller is detatchable..but still, if a cop wants to have a look inside your kick panel, you are a sitting duck.
My point of view anyway.
My Power FC cleared regency earlier this week... he took a good look inside the kick panel. :D
+1 however I will clarify that some Nistune boards use the stock consult interface - so effectively there is no way to tell unless one disassembles the ecu housing (and then removes the outer circuit board) ... nistune supports the std nissan consult interface too so there is also that...
tis illegal yes but virtually impossible to spot unless they know specifics.
also, powerfc circuitry fits inside stock nissan ecu housing, mounting it in a stock housing is a common stealth mod
-D
-D
ok thanks I got a r32
The differences are that P-FC has 20x20 maps and Nistune has the factory 16x16 maps. This really doesn't make a difference as the ECU will interpolate between the map points. So really unless you are making huge power like 600+hp and you need to stretch you map to cover a large load range you will not be at a disadvantage, and really an extra 4x4 points isn't increasing it dramatically anyway.
The Big Difference.
Nistune retains Knock Control where as P-FC does nothing to control knock except flash a LED light on your dash. So Nistune will richen you fuel map and pull timing out ignition map if a knock incident is detected but P-FC will flash at you while the engine is pinging it's tits off.
The cost.
Nistune: Board ~$250, Software/Licence ~$200, Cable ~$100.
Really all most people will need is the board, if you want to play (at your own peril) or data log then you can get the licence and the cable. Not sure whether the OBD2 tunable boards need the cable.
P-FC: ~$1000 second-hand, FC-Logit ~$450.
Without FC-Logit you can't do the things you can with nistune and the software.
The Big Difference.
The cost.
Knock control from Nistune is great however you will find that the controlable map points are very limited(up to 4500rpm only) So after this RPM both nistune and PFC will let the engine Ping...just the PFC will let you know about it
The Resolution of the Nissan map is less than the 20x20 of the PFC which gives smoother more accurate response at any power. Especially in the transition onto boost area where high resolution can do wonders to drivability.
They are both good for there respective cost.. but you do get more functionality when you pay more.
What do you mean by this?
the controllable map points are very limited(up to 4500rpm only)
There are two completely different Maps. One regular map and knock map both maps are 16x16. When a the knock count gets about a certain point it switches from one regular to the knock map which has all the 16x16 resolution that the primary map has and isn't limited to 4500rpm.
Are you saying that after 4500rpm it won't switch to the knock map?
yes, the controllable area's of the Map are limited. I'm sure the Nistune guys can fill you in. Since your also in Adelaide...we most likely talk to the same person =) Especially if he drives a mazda 121 with a twin cam.....
Never heard of the nistune not having knock control after 4,500rpm. Probably better off spending the extra money and getting a PFC.
Don't get scared off a Nistune based on a "he said they said" basis. Call Nistune themselves and speak to the guys direct. Nistunes retain knock sensing throughout the rev range ... PFC will just flash a light at you.
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
