Looks nice,
Impul body kit and an aftermarket FMIC. (maybe a Impul ECU in there also)
some sort of aftermarket suspension. Looks like the the CV boot seals are a starting to come off.
The M35 is a much more refined car than the C34 and lots more torque. A bit more of a cruiser.
You should enjoy.
There is lots of information on this forum about trouble shooting problems.
https://www.sau.com.au/forums/topic/331077-new-from-uk/#findComment-5376654
VIN number printed on your windscreen (from the first photo), when entered into FAST tells us your car was manufactured June 2002, Exterior Colour code: KYO and interior is G (grey). Motor is VQ25DET, 4WD, 5 speed auto, Model type is 250TRSFV
Model: TLGNRSNM35UDA-A--
I recently upgraded from a '97 n/a Stagea 25X to a 2006 RX250 FOUR n/a and haven't been disappointed in any way. It's a far more modern and refined car. Quite a bit higher driving position, better economy and handling. A very worthy successor to the old model, although looks don't appeal to everyone. I always thought the old Stagea was one of the best looking wagons on the road.
Edited by Spong
https://www.sau.com.au/forums/topic/331077-new-from-uk/#findComment-5376678
can't wait got the back spoiler as wellas the eye lids and some nice 20's to go on will 20's fit ok
https://www.sau.com.au/forums/topic/331077-new-from-uk/#findComment-5377002
With nice slim profile tyres, 20's may be ok but I would look for someone with 20's and see what they have to say about it.
Lots of M35's getting around with 19's but that's not to say 20's wouldn't be possible. I know the best offset is +38.
Remember if you have an all wheel drive (atessa) vehicle, keep the wheels and tyres the same all round (or atleast ensure your rolling diameter is as close as possible) or the atessa will have something to say about it.
https://www.sau.com.au/forums/topic/331077-new-from-uk/#findComment-5377060
very nice! and congrats on being the first in the UK
+1 on getting that CV boot replaced correctly. that said, if its beyond fixing, replacement shafts are available on the yahoo auctions.
nice front mount hidden in there too :)
https://www.sau.com.au/forums/topic/331077-new-from-uk/#findComment-5377226
wot do they do to a full tank hope its better then my old stag
Edited by enza
https://www.sau.com.au/forums/topic/331077-new-from-uk/#findComment-5378613
just got me nm35 one of the frist in england , have a old stagea as well , how do the mn35 run never seen one or been in one ,how do they compare to the old one ?
Congrats.....nice car....if you into Mods you have a big learning curve......or a lot of reading!
First thing to look at doing is the Dump pipe!
https://www.sau.com.au/forums/topic/331077-new-from-uk/#findComment-5378806
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
