Looks nice,
Impul body kit and an aftermarket FMIC. (maybe a Impul ECU in there also)
some sort of aftermarket suspension. Looks like the the CV boot seals are a starting to come off.
The M35 is a much more refined car than the C34 and lots more torque. A bit more of a cruiser.
You should enjoy.
There is lots of information on this forum about trouble shooting problems.
https://www.sau.com.au/forums/topic/331077-new-from-uk/#findComment-5376654
VIN number printed on your windscreen (from the first photo), when entered into FAST tells us your car was manufactured June 2002, Exterior Colour code: KYO and interior is G (grey). Motor is VQ25DET, 4WD, 5 speed auto, Model type is 250TRSFV
Model: TLGNRSNM35UDA-A--
I recently upgraded from a '97 n/a Stagea 25X to a 2006 RX250 FOUR n/a and haven't been disappointed in any way. It's a far more modern and refined car. Quite a bit higher driving position, better economy and handling. A very worthy successor to the old model, although looks don't appeal to everyone. I always thought the old Stagea was one of the best looking wagons on the road.
Edited by Spong
https://www.sau.com.au/forums/topic/331077-new-from-uk/#findComment-5376678
can't wait got the back spoiler as wellas the eye lids and some nice 20's to go on will 20's fit ok
https://www.sau.com.au/forums/topic/331077-new-from-uk/#findComment-5377002
With nice slim profile tyres, 20's may be ok but I would look for someone with 20's and see what they have to say about it.
Lots of M35's getting around with 19's but that's not to say 20's wouldn't be possible. I know the best offset is +38.
Remember if you have an all wheel drive (atessa) vehicle, keep the wheels and tyres the same all round (or atleast ensure your rolling diameter is as close as possible) or the atessa will have something to say about it.
https://www.sau.com.au/forums/topic/331077-new-from-uk/#findComment-5377060
very nice! and congrats on being the first in the UK
+1 on getting that CV boot replaced correctly. that said, if its beyond fixing, replacement shafts are available on the yahoo auctions.
nice front mount hidden in there too :)
https://www.sau.com.au/forums/topic/331077-new-from-uk/#findComment-5377226
wot do they do to a full tank hope its better then my old stag
Edited by enza
https://www.sau.com.au/forums/topic/331077-new-from-uk/#findComment-5378613
just got me nm35 one of the frist in england , have a old stagea as well , how do the mn35 run never seen one or been in one ,how do they compare to the old one ?
Congrats.....nice car....if you into Mods you have a big learning curve......or a lot of reading!
First thing to look at doing is the Dump pipe!
https://www.sau.com.au/forums/topic/331077-new-from-uk/#findComment-5378806
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 12 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I’ve also seen them explode from the binding
    • Take this with a pinch of salt, it's from someone (me) who got annoyed with turbos entirely. I hated aftermarket lines. If I had the option to use hardlines with whatever turbo I had - I would use them, 10/10, 100% of the time. The only reason people go larger, heat resistent, shielded lines etc is because they have to. And yes they don't last forever. Even if you spend big bucks on all the best heat shielding money can buy, with the best heat resistant, fuel resistant, oil resistant, radiation resistant hose, they get stiff and break down and just don't last the way a metal pipe will.
    • Unfortunately I am quite literally halfway across the globe. So all sources for parts like that are far away for me. What do you mean by that exactly?
