hi there..
so i recently replaced the timing belt on my stag... i also put a hks 2535, coilpacks, and just a general service
timing belts back together but the car wont run...
i did get it started once, it sounded like it has a SERIOUSE exhaust leak... (really tracktorish... like when my exhaust gasket was gone on the 260... it ran for about 2 seconds b4 i cut it out cos it sounded rude..
couldnt start it the next 2 times i tryed.... didnt wona cain anything so i stoped
what i did with the timing belt was....
marked the cas up
undid all the shit n took out the old belt
changed idler pulley
loosely put the tensioner in
lined up the 2 cam gears EXACTLY with the marks.
put the harmonic balancer bolt back in and span it around to line up the bottom marking. (bottom right of the cog standing infront of it)
it was fairly hard...
i used a breaker bar that was more than half meter long to do this... with some force....? is this normal... how have u guys moved this in the past...??once that was lined up, i put the belt on did up the tensioner... and then cracked the bolt back off... (everything was moving together at that stage... but would have been running backwards to undo the bolt? is this ok? it was semi tight...
put it all back together and with the cas the needle that goes into the cam wheel area needed to be rotated and fiddled with to find its spot... bolted up n all looked good...
how ever the car wont start... it makes noise but doesnt seem to fire....(starter motor having a great time)
excuse the shit thread.. its 3am and have had the car off the road for some time now playing with it...:)
from what i can tell it seems to be seriously out of time? but i cant check it without the car being on... with the light...
i dont need to line the bottom cog up with anything to do with where you check the base timing with the light.. do i??
seems odd coz all the lines on the belt lined up well...
https://www.sau.com.au/forums/topic/331113-timing-belt-dramas-car-wont-start/
  • Replies 43
Posted Images
+1 oh no
Adam, are you telling us that you decided to spin the various ends of the engine independently from one another?
(and had to use a breaker bar to do so?)
If the answer is yes, then I think that that amount of force you exerted on the breaker bar was slightly more that what is required to bend valves...
ben i put the intake and exh cam wheel to there mark b4 i did this... what position would they be at?... i spose all the valves are never all open or shut tho... so i would have had to have push threw one... it didnt feal like it tho.. just felt like on a motor bike kick start pushing threw the compression cycle... if you get me?
cas is pluged in yes... did it a few times to get a super fresh connection... wheres the best place to start looking :)
how have u guys span the cogs to there spots? left the belt on an its quite easy or?
I see you are reading Sk's tutorial. Did you read it before you did the job (especially the bit that says "This is a picture of the camshaft orientation, you need to make sure they are both at TDC, when you start, when you finish and at all times in between"...and same with the crank)?!
I followed SK instructions to the letter. Did two S13s and my Stag. Did not even have to alter the timing. It was a 10 out of 10
job.
Ok so Ive pulled everything back out and re-done the timing belt to make sure all is A Ok.
Both of the cams are lined up
The crank pulley is lined up
Thrown the belt on and put the harmonic balancer bolt in the crank and turned the engine over by hand with breaker bar, It spins with some resistance in intervals and after about 3/4 of a full crank rotation it gets VERY tight and is hard to move any further with the breaker bar. Feels like its hitting a brick wall really.
Does anyone have any ideas on whats going on? Once again everything is at TDC but still having this issue.
Perhaps when previous owner in japland had something done the cam wheels could have been taken off and put on at different orientations making the markers on them incorrect? Is this possible?
Mate, you bent valves or worse. You should line up the timing BEFORE removing the belt. Engine won't start due to compression loss due to bent valves. Time to pull the head off.
roo im pretty sure it doesnt matter when you line up the marks aslong as it gets done... but i could be wrong.
im starting to think the issue is something in the engine cycle somewhere.. somehow... maybe somthing in the spark plug holes!
i totaly re did the timing belt to absolute perfection today, the 1st time we tryed to start it just hit this 'hard spot' we are talking about,
after that i moved the crank pulley with the breaker bar and it started... but still this really loud tractor noise... very exhaust gassie..
would a serious crack or gone gasket in the exhaust manifold cause it to make this bad noise and run really shit.
throw it out there.....
i did also change turbo to a hks 2535
timing belt,
oil,
sparkplugs..... NGK BCPRE6 0.8mm i did line them up to the old ones (1.1m gap) . so im doubting its a funky sparkplug...
coilpacks
coilpacks in the car now are the stockies... so its not them,
oils there, with no coolant. so i didnt mess up any lines on turbo,
Edited by chef_stagea
Unfortunately, this may be the case.
I NEVER turn any of the pulleys without the belt on. Especially not the balancer, but in anycase, never any of them.
E.g. I had to replace the cam seals. I forgot to crack the hex nuts/bolts on the left hand cam. I had to put the belt back on before I cracked it, cracked the bolts/nuts, then took the belt back off again.
When I turn the engine by hand via the crank bolt with the spark plugs in, it is firm, but not what I would call very firm or difficultly firm. Also, I don't feel any differing levels of firmness throughout the rotation. I turn it using a 42mm breaker bar with light - medium strength.
Edited by MANWHORE
is there a semi easy way to tell if ive smahsed them up?
no point taking the head off to find nothing... will there be much to see down the spark plug holes? worth taking the exhaust manifold off for a looksie?... or again not alot to be seen?
and will the car run with bent valves...
im unsure... because the 1st time i did the belt... the 2nd time i went to start it it wouldnt fire... but span freely... but that hardspot was there... i also used a half meter breaker bar... and needed 2 hands to crack the bolt off with a fair bit of pressure.
The "really bad exhaust leak" sound you are hearing is likely the compression from a cylinder leaking past a bent exhaust valve no longer sealing the cylinder. The "tight spot" you keep coming up against when you turn the engine over is possibly a valve bent at its full extension into the cylinder.
At this point, there is no cheats way to diagnose your problem and continuing to turn the engine over, is only likely to end in more damage.
Pull the head off and assess the damage. Sorry mate, it happens to most of us at some point if you play with cars.
Could you take the rocker covers off and see if the valves are going in and out like they should. But it sounds like to me its a bent valve. The valves could hit if one cam is turned and not the other. Ive replaced valve springs on a v8 head by filling cylinder up with compressor air which holds the valves up. Could you try something like that with the cams off so that when you ad compressed air the valves will go up and seal them into the head. Its another way of doing a compression test i guess if you cant crank it over.
You must line up timing marks with belt still on. I'm convinced you've bent valves. Turning the cams opens valves out of time with the crank. Then forcing the crank to turn makes the piston bend valves. Way to test is remove cam covers and check valve clearances. A big gap means valves are bent and not seating properly. Meaning compression loss.
So if this is the case that I've bent valves is this going to ruin a fair bit of stuff? Or would I have most likely only hit one? .... Not going to be cheek hey!
So were agreeing the head needs to come off??
After I've tried taking out sparkplugs and spinning it... Ahh wow!
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
