Your best bet is to take the car to a engine reconditioner and just say that you dont want it back till it runs
sounds like bent valves hope they havent made there way in to the pistons
good lesson for everyone to learn to bad it had to be you to show everyone
somethings should be left to the professionals
  • Replies 43
Posted Images
so ive confirmed my issue not a belt valve... it is infact a snapped valve. and what appears to be piston ring in the top if the chamber...
plan off attack is not get a few of the local stag boys together to help remove the head...
if the piston ring is damaged i will need to go in threw the sump :P... theres a seriously good chance now that both the top of the piston, and side wall is seriously hacked!
not going to be a cheap exercise!... how ever all other spark plugs were in tacked, and didnt appear to have any stay shit flying around... but only time will tell 100% !!
do i need to pull the rocker covers off b4 the head? had a look and i cant really c many attack points for the head lol... hopefully once the intake mani and turbo is fully off it will expose more bolts!!
any of you adelaide boys that want to come round sunday to give me a hand along with a few others, would be fantastic!! ive msgd a few of ya already :O
Edited by chef_stagea
pretty sure all the head bolts are under the rocker covers
its good tho, keeps them nice and slippy
bad news about the missing valve tho
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
