as the title says, on my old piping kit i had a line comeing out of the intercooler piping just before the crossover pipe that went to the boost controller then to the wastegate, but the jjr kit dosent have anywhere at all on the piping to put a line.
where do i put the ling to the boost controller/wastegate actuator? where do i T it into? please dont say i have to drill into the piping and put a line in...
cheers
it should come from the intercooler pipe work like the stock setup did
or even better from the compressor cover itself (r32 style)
but you can also get it from the back of the plenum, where the stock boost guage get's it signal from
i was thinking doing it from the stock boost guage line, i have teed it into the BOV line before the bov near the plenum, is this ok? i have been getting issues where the car starts to cut out while driving ever since i installed the new piping, could this method be causing it to die?
Dont hook it into the charcoal canister hose, the bosst reading is too inaccurate, the bov hose will make it run more boost, and being after the throttle, can cause some running issues. Just screw a fitting into the piping just after the turbo
is that the black arm pipe that then goes down to the intercooler?
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
