http://www.horsepowerinabox.com/HPIAB2/prod641.htm
I might order one of these tomorow what yas think of price and size I don't care about lag
Do not buy that one.
If you are going down the route of a GT3076 then you will need a T3 flanged (not T25 SR20 type exhaust flange).
I would sit down and have a really good think about what you want out of a turbo before acting as you will save money in the long run by thinking it through.
I am not a fan of the turbine housings that bolt up to the stock dumps as I have never seen them allow the full potential of a 76mm compressor.
If you go down the path of a complete Garrett unit then you need to consider dump, oil/water lines, intake changes and you will need new injectors even with the correct HPIAB GT3076 with T3 flange there are still issues with oil/water line and intake changes.
https://www.sau.com.au/forums/topic/331132-wtf/page/2/#findComment-5379999
If you're thinking of that exact one in the link, then don't do it. It's in a T25 flange and is made to fit SR engines.
Look for one that is in T3 flange :D
Edit: Dammit, beaten :)
Edited by d1_drifter
https://www.sau.com.au/forums/topic/331132-wtf/page/2/#findComment-5380002
i no its not that one i need but morrie at from that place says he has the one for rbs and the oil n water lines arnt much of a hassle. and im doin the exuast to suit so that doesnt matter.
i was gona get him to fit it so he can deal with it but now i have the motor striped down i was gona do it myself and just give it to him to tune.
i want to spend about $1600 to $1800max just on turbo.
if yas wana thro ya sugestions down go for it. just remember lag doesnt bother me, so must be in the 30s
https://www.sau.com.au/forums/topic/331132-wtf/page/2/#findComment-5380071
cars got 200wkw now with fmic pod no rear muffler and nistune set at 14 psi (droping to 9)
want to get 250wkw with
new turbo $1600
fuel pump $150
afm $200
exhaust$800
if injectors can handle it il do them later and what ever else to get 300wkw
https://www.sau.com.au/forums/topic/331132-wtf/page/2/#findComment-5380105
Ild be happy with 270 to 280 if that's about all that turbo can make I'm just Gona run it at what Eva the injectors can handle for now untill I get more coin. The exhaust and other bits are Gina send me broke for a while
https://www.sau.com.au/forums/topic/331132-wtf/page/2/#findComment-5380898
Trying to pay mortgage on one wage at moment so budget isn't looking good for injectors.
Has anyone got sum of that metal paste stuff I can steal so I don't have to buy a $50 tin of it?
https://www.sau.com.au/forums/topic/331132-wtf/page/2/#findComment-5381030
You won't need the afm if you don't change the injectors. Save the money for your turbo - total installation costs will be more with bits and pieces. Also I think fuel pump will cost more than $150 and afm will be $300.
Just do the turbo and fuel pump for now. What are you using for boost control?
https://www.sau.com.au/forums/topic/331132-wtf/page/2/#findComment-5381108
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
