Anyone have any idea on what the GTR is doing?
There is a few symptoms:
- exhaust temperature light is on(when it comes on it does the stuff below)
- on idle it struggles to stay at a stable rev and conks out
- when driving it feels like engine drops power for a split second (driving along it feels like tugging on the handbrake quickly) numerous time while the exhaust temperature light is on
Faulty sensor? But I didnt think the sensor does anything besides lighting up the dash light when the exhaust temp is too hot...
If I cant diagnose it I guess I'll have to leave it to the tuners to figure it out since I'm booked it for a dyno run touch tune etc anyways....
https://www.sau.com.au/forums/topic/331137-what-is-my-r32-gtr-doing/
Its got a de-cat pipe in there though... it even did it with the standard cat which I had on for Vehicle Inspections for awhile - didnt drive it around too much when I had that on.
It only did it a few times ever before I put the standard exhaust/cat back on for vehicle inspection(roadworthy) and then it seems to be more frequent ever since, even after I put the aftermarket more high flowing exhaust on with the de-cat pipe.
coilpacks and spark plug has been changed, injectors no...
Why would it only happen here and there and only briefly though when the exhaust temperature light is on?
Seems to be more worst today as I took it for a drive, come home park it up, went elsewhere in another car for about half hour come back turn it on and it started doing it nearly straight away and conked out, drove it down to the car wash and it conked out as I left it to idle and hose the car down, turn it on drove it home(its only a 1 minute drive per way), went into my driveway and turn it off as the engine was struggling to have a stable idle - then needed to move the car about 15 minutes late so turned it on and it was still doing it doesnt stay stable and wants to conk out unless I keep my foot down on the accelerator so the rev doesnt drop down enough to conk out.
check which light you are seeing and check what it means in the service manual before guessing the cause
there are two lights that come to mind
one is the ENGINE CHECK LIGHT or orange ENGINE logo
the other is the EXHAUST OVER TEMP or RED CAT LIGHT
which one are you getting and check what it says in the service manual
ie no point guessing AFM's coilpacks etc if it's the RED CAT LIGHT as that's the CAT TEMP sensor warning
given you have a powerfc when the light comes on, use the hand controller and read what it is telling you
for an online demo and what you should be looking for check out
http://www.paulr33.com/powerfc-emulator/menu.html
you want to goto ETC, SENSOR SW CHECK
and then with the online emulator, learn how to work out what is wrong
Ah the PFC hand controller - I totally forgotten about that, took it off for vehicle inspection.
I just hooked it up, turned it on and left it to idle and after awhile it started doing it again so I quickly jumped back into the car and on the hand controller "AF-1" was highlighted and dropped down to 0.00v...
because the 32 gtr only has a cat temp light, not a cat temp and engine check light :D it is PFC showing you an error, looks like youv'e found it already.
if you can't easily get your hands on another afm to try, swap the 2 around and see if the error now apears as AF2
Hope its just a really dirty AFM, which it was - and I've cleaned it out with some contact cleaner earlier. See how it goes tomorrow when I take it out to the tuners for a dyno run check up and tune.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
