Anyone have any idea on what the GTR is doing?
There is a few symptoms:
- exhaust temperature light is on(when it comes on it does the stuff below)
- on idle it struggles to stay at a stable rev and conks out
- when driving it feels like engine drops power for a split second (driving along it feels like tugging on the handbrake quickly) numerous time while the exhaust temperature light is on
Faulty sensor? But I didnt think the sensor does anything besides lighting up the dash light when the exhaust temp is too hot...
If I cant diagnose it I guess I'll have to leave it to the tuners to figure it out since I'm booked it for a dyno run touch tune etc anyways....
https://www.sau.com.au/forums/topic/331137-what-is-my-r32-gtr-doing/
Its got a de-cat pipe in there though... it even did it with the standard cat which I had on for Vehicle Inspections for awhile - didnt drive it around too much when I had that on.
It only did it a few times ever before I put the standard exhaust/cat back on for vehicle inspection(roadworthy) and then it seems to be more frequent ever since, even after I put the aftermarket more high flowing exhaust on with the de-cat pipe.
coilpacks and spark plug has been changed, injectors no...
Why would it only happen here and there and only briefly though when the exhaust temperature light is on?
Seems to be more worst today as I took it for a drive, come home park it up, went elsewhere in another car for about half hour come back turn it on and it started doing it nearly straight away and conked out, drove it down to the car wash and it conked out as I left it to idle and hose the car down, turn it on drove it home(its only a 1 minute drive per way), went into my driveway and turn it off as the engine was struggling to have a stable idle - then needed to move the car about 15 minutes late so turned it on and it was still doing it doesnt stay stable and wants to conk out unless I keep my foot down on the accelerator so the rev doesnt drop down enough to conk out.
check which light you are seeing and check what it means in the service manual before guessing the cause
there are two lights that come to mind
one is the ENGINE CHECK LIGHT or orange ENGINE logo
the other is the EXHAUST OVER TEMP or RED CAT LIGHT
which one are you getting and check what it says in the service manual
ie no point guessing AFM's coilpacks etc if it's the RED CAT LIGHT as that's the CAT TEMP sensor warning
given you have a powerfc when the light comes on, use the hand controller and read what it is telling you
for an online demo and what you should be looking for check out
http://www.paulr33.com/powerfc-emulator/menu.html
you want to goto ETC, SENSOR SW CHECK
and then with the online emulator, learn how to work out what is wrong
Ah the PFC hand controller - I totally forgotten about that, took it off for vehicle inspection.
I just hooked it up, turned it on and left it to idle and after awhile it started doing it again so I quickly jumped back into the car and on the hand controller "AF-1" was highlighted and dropped down to 0.00v...
because the 32 gtr only has a cat temp light, not a cat temp and engine check light :D it is PFC showing you an error, looks like youv'e found it already.
if you can't easily get your hands on another afm to try, swap the 2 around and see if the error now apears as AF2
Hope its just a really dirty AFM, which it was - and I've cleaned it out with some contact cleaner earlier. See how it goes tomorrow when I take it out to the tuners for a dyno run check up and tune.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
