I just got my car back from a mechanic after someone interested in buying it booked it in. This mechanic tried to tell me that the diff could last between 500km and 5000km, the buyer was there too by the way. Now my brother also has a skyline, but his diff whine is so much louder than mine, and has been so for far more than 5000km without getting any worse. How can this guy try to tell me that i have as little as 500km left in my diff when I've been told by other mechanics that it could last forever? Is this just a ploy between the mechanic and buyer to get me to lower the asking price? Oh, and how much would a replacement diff?
have u ever changed the diff oil? it could be a stuffed axle bearing. youll still be able to drive it, its only when it gets really load that i think u need a new diff.
that happened in our r31 at around 670000kms. but we didnt get a new one we just got the old one fixed because they were quiet expensive at the time new.
its now got to 220000kms on the original diff
I haven't personally changed the oil, but I've only owned the car since July last year. I just want to get a realistic idea of how many k's there are left in it.
Edit: I've got 212,000 on the clock by the way.
if you hear the noise while you accelerate and get of the petrol it's usually a gear backlash or worn gear issue. but if its a constant noise its most likely to be a bearing problem.
though yours brother diff sounds like its on the way out.
r31nismoid is right, alot of the r31 diffs have diff whine. its not something uncommen
I used to have an R31 (for about 8 years!). Since the word GO, the diff had whined ALL the time (as you said, around 80km/h) - was worried about it at first, until I kept getting the same story that THEY ALL WHINE, THEY ALL DO IT. As I said, I had the car for about 8 years and NEVER had any problems with the diff (and yes, I wasn't easy on the car). When I sold it to my parents 2 years ago, it had 365,000 on the clock. They've still got it, the diff still whines, and they have had absolutely no problems with it at all.
Well, the problem is that it has just scared off my most promising buyer so far. He just rang today and told me that he doesn't want to buy it now, specifically because of the diff. There was no convincing him. I really need to sell it, I move down to melbourne for uni 3 weeks. AHHHH!!!
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
