  • Replies 174
Zennon - Very good work with the wedding pics. The couple will be very happy no doubt. So tell me how you felt after shooting your first wedding?
Yeah not bad - wasn't a paid gig so was only a little nervous
Wish I had fast zoom lens 17-55/2.8 or 24-70/2.8
and a proper flash SB-900 (or sigma equiv)
Indoor shots were all either really high ISO shots or
shots with the built in flash which are never very flattering
Dude, snap up a Sigma EF530DG-Super from DigitalRev in HK. I had one of these and decided I'd like another, and saved myself close to $200 compared to the shop I bought my first one from. Shipping was quick too.
Sit in sau. Haha.
The short answer is smash cars. The next shortest is I make sure we acquire the data from the dummies and instrumentation. Need to maintain the instruments and systems used to capture data. Build stuff, play with high speed cameras, computer stuff. Lots of needy stuff :P
I took my car for a clean on the weekend and took some snaps. Here are a few of the good ones. I took them with a cannon powershot G11 :huh:
I thought for a second I was looking at my car ... Another silver R34 sedan with white wheels, love it!!
Now considering deleting weather shields on mine, looks heaps better without.
also - your mirrors seem to be broken :P
Naa not broken they fold in when the car locks :ermm:
Really? i was thinking of getting some can you pm me a photo of your with them on?
Couldn't you have taken pics with the car unlocked?
I'd probably go shoot again, but find some angles on the car that aren't at normal head height. try to create a bit of interest. Nice choice for BG though :)
    • Anyone want to make me an offer to take my v36/g37 3.7l manual coupe in full? Off memory it was low 100k km but the battery is flat so can't tell right now. What's wrong. I had engine problem's that led to a nice clunk. It made it home but it wasn't pretty for the last few kms. Happened under revs. Sounds like bottom end.. never got around to fully checking or fixing it so the car has sat still and unregistered for a few years. Minor bump in front end set the pedestrian protection under bonnet airbag off and that was meant to be repaired, but while waiting for the repair (parts to come) I got the engine problem. The rest of the car is in decent condition. All drive line is good. All interior is good. Leather interior. Wheels in good condition and decent tyres although the ps4s are likely a little too old now it's sat still. Colour of the car is pewter off memory, the dark grey colour. In Camden NSW. Would need a tray back pickup.
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
