Hi everyone I have come across a FJ20ET powered DR30 very cheap. It has a few problems but is running, rego'd and all original under the bonnet.
My question is that given that it is not a RS Turbo model, what would be a reasonable price to expect for a DR30 given that it would be restored: i.e. repainted, re-sticker-ed, replaced interior/exterior trim, and given period mags? Essentially how much are people willing to pay for a mint example?
I have a choice at the moment of restoring an early soarer or this so any advice would be helpful, the only difference being this has rego and is not as ugly.
Thanks.
https://www.sau.com.au/forums/topic/331236-advice-regarding-dr30-skylines/
Forget the soarer...
This DR will be lighter, and much more nostalgic and fun!
D-limo has one for sale, I think he wanted $4000 or something. There was some interest, but nothing epic. (it needs alot of TLC, basically a short-term project car)
Any where from $3000 or so is a good price for a 'project' and $5000 and up for a driveable one. $10,000 is the best Ive seen a higly modified one go for, had a very sexy engine too
Okay site has been down or my computer fried and couldn't post.
The soarer is a GZ10, yes, and its in pretty decent condition.
Only space in the garage for one more sh!tter, er I mean project, unfortunately.
Its a coupe, it has minor rust patches but is for the most part an easy repairer. In Tassie it is cheap too - $4000 - and we normally get the raw end of the stick when it comes to prices.
The only problem left is the missus who prefers the soarer to the skyline... Anyone got some good arguments, shes a hard one to persuade :whistling:
Rust (boot, front guards mainly) and interior completeness/condition.. Two things to look for that will cost you in the long run. Think I've had 3x z10's :laugh: and on my 5th dr30.
Soarer is more of a cruiser, usually auto, heavier, no lsd.. when you drive even a stanadard dr you know its a sports car.
Tidy Soarer prices are gaining ground in Japan, as are dr30 but we've been waiting for the flow on effect for years.
Edited by D-limo
  • 4 weeks later...
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
