I bought this a few months ago, but have decided not to build a new engine just yet
It is Rb26 R33 GTR head, reco 25,000k's ago. No porting done.
It is perfect condition.
It was setup for the Clive cams, 272deg 9.15mm lift
Clive cams included
$1300
Or head only with stock cams, may need to reshim (??) $850
Clive Cams only $600
Made in Melbourne
R33 GTR inlet plenum and throttle bodies
No injectors or fuel rail or TPS
$425
Pick up Brisbane
Will post interstate
Clive cams included
$1300
Made in Melbourne
$425
Pick up Brisbane
Do u still have this head?
If u do can u give me a txt on 0422590648
Cheers braden
Cheers braden
Sorry head and cams sold in the first day
Still have inlet
I do have a stock rb26 head if interested?
Hey mate keen just waiting to hear bak from u.
have sent you a Pm with contact details
You will not be able to PM yet, need 10 posts
  • 4 weeks later...
    • Sell it and buy something newer? 😛
    • Better then PooPooG... or is it PeePeeG?
    • The steering wheel on my 97 s3 gtr is a little bit worn out, so im on the hunt for something mint. I notice that this type of steering wheel is on several other nissan's of the era.  Does anyone know if their all identical, or are there slight differences? I feel like gtr tax applies to anyone selling one, but if it comes from any other car the price is much less, even though its the same design.  Chat gpt says the material for the gtr is slightly different and it says gtr on the wheel, but every pic ive seen it just says nissan.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
