No Wakkie this weekend :(.
Just a cruise meet n greet between NSW and ACT.
http://www.skylinesaustralia.com/forums/topic/418972-mid-march-mid-way-meet-up/page-3#entry6772390
Think there is a thread in NSW section - luke's the Orgyniser
  • 1 year later...
  • 6 months later...
So I was researching this issue and came across this thread. Looks like I have the same issue. On cold starts the 4WD system always works fine but sometimes on hot starts the 4WD error light comes up on the dash and the car is in permanent 2WD mode.
Had a look and it always seems to be error code 18.
Joey did you ever solve your problem mate? It's just painful with no 4WD the car is way to tail happy. I'll start testing this weekend hopefully but any insight would be appreciated.
  • 1 month later...
Just wondering if you guys resolved this problem?
I have an R32 GTR with error code 18. Tested the circuit as per the workshop manual and it's all good. However 4WD light stays on permanently and attessa pump only primes rarely on startup.
Any input from other people's experiences would be appreciated before I begin to change pressure switches and pumps out of desperation!
Look at the positive terminal on the battery. See if you can replace/improve the links.
Ravi - if you are replying to my comments I have a new battery and new cabling, solid connection. An auto elec also tested the entire Attessa circuit and all powers up fine.
Summary of my issue:
- 4WD and ABS lights stay on constantly
- Attessa computer reporting Error code 18: “ETS pressure switch or circuit fault”
- Auto elec checked all circuits and wiring thoroughly, all is ok
- 4WD pump primes on initial startup but no pressure going through lines to gearbox
- When pump is forced to prime (sending power direct to pressure switch) no fluid is coming to gearbox
Might have to bite the bullet and replace the pump!
Tried replacing the nitrogen canister above the rear diff ? It's 25 yrs old.
And I should add not cheap at around $400
That and then a flush of the fluid to be thorough
Made me a happy camper. :)
Haven't tried, but makes complete sense to do so. Any advice on where I can get a new nitrogen canister?
Thanks for the response!
I didn't have any errors, but i replaced my canister and it totally changed the behaviour of the system during bleeding.
I got mine from rhdjapan (few months ago) it was about $280. My pump was starting to make funny noises from running all the time, wish I had changed it ages ago
  • Like 1
  • 6 months later...
Very late reply, I did end up solving the issue mate, what the issue actually was, stuffed if I can remember haha think it may have been battery related
I've actually got another fault now so will be interesting to see what that one is as well
Did this fix it mate?
Yes my 4WD is working like a dream now. Fitted the new nitrogen canister and bought a digital G-sensor to replace the old original sensor... Car hooks up all four wheels almost instantly on the track! No tail happy over steering with delayed torque split anymore.
Next I will rebuild the transfer case to ensure best possible mechanical engagement.
  • Like 1
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
