hi iv tryed all the wreckers in my area and no one will sell an actuator without the turbo
what my problem is im about to put on a 3" tubo back exhaust but for some reason the owner in japan put a 12psi actuator on so if i put the exhaust on my turbo will be booting too high for it to handle,
does anyone have or know of someone that has an r34 gtt standard turbo actuator that i can buy ?????, oh yeah im melbourne area !!
thanks for you help
Well i have one of Stagea S2 Neo motor,so if that`s any help ,iaam in Perth so if you want it let me KNOW ,
cheer`s Chuckie.
i dont need the motor but if your willing to sell me the turbo actuator ?? that will be great
couldnt you just put in a boost controller?
now my mate sugested that but my actuator is set to 12psi and it will go up to 14 psi when the exhaust goes on (well thats the general outcome with people on this site.but i was under the impressiong boost controller can only up the boost not drop it ???
People who put R32 (10psi) actuators on their R34 typically have their boost sit rock-solid on 10psi, so not sure that's true. I suspect it's more of a case with the factory 5psi actuators being overcome by the extra flow of a new exhaust which is why they flow higher, but maybe I'm wrong.
I'd be sticking with the current actuator and seeing how you go - replace it if it becomes an issue.
(And yes, boost controllers can only go as low as the wastegate actuator is)
yeah im going to do that i just want one spare (i know if its boosting to high just dont put the foot down all the way ) so if its too high i can take it easy untill i replace the actuator (if it changes boost )
thanks for the advice people hopefull i can still get hold of one (just incase )
just to be clear
R32 GTST actuator is 12psi
R33 GTST Manual actuator is 7psi
R33 GTST Auto actuator is 5psi
so fare chance i have a R32 GTST actuator at 12psi
so is it un common for a car in japan to have an upgraded actuator but not turbo ??
only reason i ask is because i havent pulled the pipe off to see ?
the common actuator upgrade we see is the R33 GTST with R32 actuator
thats the only common actuator change that im aware of
ie you wouldnt fit a 16psi actuator to R33 GTST turbo as the turbo cant safely flow that much
also look for std actuator specs for BNR34 and ER34 if anyone can measure/check or confirm them ?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
