As title, after I remove the standard turbo from my car this coming Sunday, it's up for grabs.
The last time the turbo was out of the car was when I had the manifold gasket/studs done by Autotech, and they advised me it was in good condition with very very little shaft play.
Having said this, it's been run on ~11psi since I bought the car (and God knows how long beforehand), so it certainly hasn't been babied while on boost.
I've only found a couple of FS threads for stock turbos, so I don't have a great idea of price. I will start the asking price at $100, which is already lower than the few other sellers I've found (around $150).
If there are any issues at all with the turbo when I pull it out to look at it, I won't rip you off lol. I'm happy for it to become a paper weight, I just thought some R32 owner might want it.
By the way, THIS IS FOR THE TURBO ONLY. Since I am swapping mine out for a highflowed turbo from Hypergear, I will be keeping the water line and maybe anything else that I still require to run the new one.
PM or reply here
https://www.sau.com.au/forums/topic/331293-for-sale-standard-r33-s1-turbo/
Just so ya know, i ended up breaking one, then making a new water feed line to the turbo.
The stocker does fit but it needs to be manipulated a fair bit to get on. And those metal pipes don't like getting bent much...
good luck with the sale too!
hole shit! everyone wants one!!!
Nar Troy, it should be fine, there's a flange between the rear housing and the middle part (where the water and oils lines go) if we grind a small peice of metal out of this flange it'll make the water line go on fine... Had i have known this before i did mine it would've saved a hell of a lot of time :bunny:
Probs just as much. Will be a bit more laggy on a 32, but would be nice for a drift car (which 32's were made for, amirite?)
Mine's more than likely being let go to wal32r, unless he changes his mind.
Remember Pat, THE BEST bang for buck upgrade a 32 GTS-T can get is an RB25 turbo. So at this price it's a steal.
it's not if someone with an RB20 wants response, my experience is they get full boost at about 4000rpm, comes on hard, but that's too lagy for me.
pretty much no one makes turbos small enough for the RB20 anymore so i'll probably look into steel wheeling my stock one
When your operating system or hardware on your PC is no longer supported by applications, it's time to upgrade.
In this case, buy a front cut R33 and be done with it! RB25 powered 32's are hawt.
  • 2 months later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
