As title, after I remove the standard turbo from my car this coming Sunday, it's up for grabs.
The last time the turbo was out of the car was when I had the manifold gasket/studs done by Autotech, and they advised me it was in good condition with very very little shaft play.
Having said this, it's been run on ~11psi since I bought the car (and God knows how long beforehand), so it certainly hasn't been babied while on boost.
I've only found a couple of FS threads for stock turbos, so I don't have a great idea of price. I will start the asking price at $100, which is already lower than the few other sellers I've found (around $150).
If there are any issues at all with the turbo when I pull it out to look at it, I won't rip you off lol. I'm happy for it to become a paper weight, I just thought some R32 owner might want it.
By the way, THIS IS FOR THE TURBO ONLY. Since I am swapping mine out for a highflowed turbo from Hypergear, I will be keeping the water line and maybe anything else that I still require to run the new one.
PM or reply here
https://www.sau.com.au/forums/topic/331293-for-sale-standard-r33-s1-turbo/
Just so ya know, i ended up breaking one, then making a new water feed line to the turbo.
The stocker does fit but it needs to be manipulated a fair bit to get on. And those metal pipes don't like getting bent much...
good luck with the sale too!
hole shit! everyone wants one!!!
Nar Troy, it should be fine, there's a flange between the rear housing and the middle part (where the water and oils lines go) if we grind a small peice of metal out of this flange it'll make the water line go on fine... Had i have known this before i did mine it would've saved a hell of a lot of time :bunny:
Probs just as much. Will be a bit more laggy on a 32, but would be nice for a drift car (which 32's were made for, amirite?)
Mine's more than likely being let go to wal32r, unless he changes his mind.
Remember Pat, THE BEST bang for buck upgrade a 32 GTS-T can get is an RB25 turbo. So at this price it's a steal.
it's not if someone with an RB20 wants response, my experience is they get full boost at about 4000rpm, comes on hard, but that's too lagy for me.
pretty much no one makes turbos small enough for the RB20 anymore so i'll probably look into steel wheeling my stock one
When your operating system or hardware on your PC is no longer supported by applications, it's time to upgrade.
In this case, buy a front cut R33 and be done with it! RB25 powered 32's are hawt.
  • 2 months later...
    • Standard GTRs are boring and there plenty of them, do what ever you want to it and just remember nothing about them is cheap anymore and if you’re picky about how you want things done it gets even worse.    if it’s an n1 or something very limited then maybe care more about it’s heritage
    • Alright guys, I've got good odds the motor survives due to a majority of spare parts. Who's taking bets on clutch, who's on transmission, and who's go diff? Happy to also take bets on if it still overheats in traffic or not 😛     Car looks amazing by the way. I've never been a fan of R34 rears, so really, I don't think any body kit etc solves that for myself, but the front end looks amazing!
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
    • For that price you could buy the hypergear turbo (big fan as I run one) and the Haltech ECU..
    • +1 for the Elite 2500. Get some new knock sensors while you are at it (pretty cheap), look up the TAARKS Nissan knock sensor kit. You may also want to get new coils (R35gtr) while your at it (assuming your on stock ones), as they are a liability. Mine started right up and idled fine on the base map. Also go MAP over MAF, as said above, Haltech make this super simple right out the box. Another fanboy of DBW here, Outsider Garage from your neck of the woods make some nice conversion gear for the R33 (that’s where I got some of my gear from).
