  • Replies 123
I had this in my diary months ago! :)
will enter the display if we have one... didn't we just rock up last year, ie not have a proper "club" display as such??
Yeah, you dont have to have a display, but some clubs would like to, so they are more than welcome
So whats the deal with this...do we just turn up to ultimate tunes on the saturday?..how much it cost for a run pull etc etc...i can see any info about this?
Andrew
no charge for the show and shine, $40 for the dyno comp.
show up on the saturday morning, if you are in the show and shine you will be given an entrant number when you arrive, if you would like to entre the dyno comp head down to the reception arear and give your details.
hmm sounds like a gower from me >_< *looks at gtr* "hey wanna go to a social event? maybe harrass a supra or two?" :D
am working dat morning so will turn up after 12pm if the event/dyno is still on :O
Now THERE'S a SAU'er I haven't heard from in a while... Googs; how goes it, mate?!?
Queen St Customs are entering a JDM car.
So why not bring some other cars up aswell?
Also their are a few cars which are halfway between JDM & Sexspec.
Anyway, car scene has been dying because of gronks like you.
Aren't we supposed to be uniting? Doesn't matter on the car, just a fun day for all to enjoy?
Same for people.
You don't exclude people for the colour of their skin etc.
Another example was C4C.
Although it was an All commodores cruise, all cars were welcomed.
Many other cars other than commodores showed up.
Another example is the BAR B Cruise.
Some of the 2SUS Cars showed up and were welcomed in, as
these events are about unting car scenes and workshops together no matter where he/she comes from.
Personally, I like a mixture between JDM & Sexspec. To conclude, if you don't like what we're bringing, then f**k off and don't look at our stand.
Regards
Edited by QSRS14
I'm not trying to exclude anyone, just suggesting it doesn't exactly fit with the theme of the day.
The car scene is dying because of the attitude people like you have across all the forums. Scares the majority of the normal people away. I'd like to point out I just asked the question, you were the one who went straight to insults.
Don't worry, I wish to keep my food down so I'll be nowhere near your stand.
Edited by GTRKat
Queen St Customs + Dahtone Racing + SEXSPEC to make an appearance.
Don't be too hasty guys.
Haven't had anything to do with Queen St, but Dahtone came to the SAU show n shine last December and had a hole heap of nice cars with them.
In fact they were the biggest single supporters of show. Bar none!
Everyone likes different things, "sex-spec" is in no way my cup of tea, but seeing some of the effort that goes into the cars is nothing short of amazing.
As for being JDM, there are "JDM" cars and scenes that would make Queen St and Dahtone look subtle :blink:
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
