Hi Guys,
We are now appointed the Australian Distributor of "Orange" TPMS (Tyre Pressue Monitoring System)
For those Track Warriors you will need this, why bother with tyre pressue gauges everytime you get on and off the track? This will not only monitor tyre pressure but also temperature live.
-Full Time (24 hours monitoring)
-Real time
-Up to 7 Years Battery Life
-Changeable Valves
-Show's tyre pressure and temperature
The Orange TPMS offer the most comprehensive wireless solution for tyre monitoring with both pressure and temperature displayed on screen for each wheel. Orange TPMS is suitable for all four-wheel passenger vehicles.
A 2007 SEMA Award winner for Best New Product, Orange TPMS offers real-time monitoring with a RF Wireless with a patented integrated antenna, military specification 3.6v lithium batteries in the wheel sensors. High and low warnings are displayed by both visual and audible tone.
Orange TPMS is suitable for your daily driver through to your four wheel drive to your race car. All styles of driving rely on the final point of contact with the ground through your tyre and providing constant monitoring will alert you to any change in the pressure or temperature of your tyres.
Orange TPMS is used by the following race teams;
Le-Mans 24 hr (Honda official formula Team)
Renault Formula Open 2000
Formula China
Motul Nismo Drift 350z (Australia)
C1 super cup (Ferrari)
GT N1 (Nissan, Honda)
F3 Japan (Alfa Romeo)
A1 (Testing in England)
Why Monitor Your Tyre Pressue?
Most people ignor their tyres. Tyres are undoubtedly the most critical saftey compnent on a vehecile. Where the rubber meets the road affests traction, handling, steering, stability and braking. Because of this, a sudden tire failure can have serious consequences, especially if it occurs at highway speeds and at the track. Yet people neglect tier tyres and assume that all is well unless they totally flat, at which point it is too late!!
In Stock $299 Delivered
how does it handle spare wheels? eg i've got 6 wheels that will be rotated over a event, and at times i might have a spare in the boot
That would be hard b/c they come in sets of 4 and all are monitored by it's corner, FR, FL, RR, RL..we will put this qestion to the manufacturer and see if they have an answer
  • 1 year later...
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
