WHAT THE HELL!!!!! ARGGHHHHHHHH god damn server!!
Here it is again sorry man
Hey guys
Ok I have an R32 2 Door R32 GTS-t
Me and Forum members decided what colour to paint it. r33 or r34 Midnight Purple
Forum members helped me out with what my wheels are. They are Racing Sparco Python Wheels
Thanks for this guys! :D
Ok now since i have the engine and box removed. What should i do to the engine bay?
Remove the battery to the boot?
Piss that pesky looking fuse box off to inside the cabin?
Remove the HICAS?
What else should i do while the engine is out?
Remember this is a street car only! :huh:
Cheers Guys
Nackerz
Hey guys
Remove the HICAS?
Cheers Guys
Nackerz
the hicas is at the rear, not in the engine bay.
Thanks. And as said more room in engine bay and looks neater. :huh:
Aint there part of the HICAS in the engine bay? thats what i read somewhere on the forum. could be wrong tho
This bit???
Edited by Nackerz
r32's have hydrolic(spelling) HICAS so some of it is in the engine bay.
Take note buy fully removing HICAS you will have to change the powerstering pump to an r33 one.
Dont just block it off.(pressure build up NOT GOOD) >_<
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
