I just recently did a rb25 swap into my r32, I cannot get the car to start, turns out there's no compression in any of the cylinders, I purchased the motor from a reliable seller who says they tested the compression and replaced the timing belt and all was good.
I didn't mess around with the timing or remove the cams so I don't believe there is any possible way I could have bent the valves, let alone all of them. the only thing I did mess around with while trying to get it started is the cas, is it possible that's the cause of no compression? and if not does anyone have an idea what else could be causing the problem? I have yet to pull the head off to check the valves.... Also its a series 2 rb25 and it has hydraulic valves
Any help would be greatly appreciated
Thanks
https://www.sau.com.au/forums/topic/331631-rb25-no-compression/
Does the engine at least spin?
Might want to check the battery and starter :/
Ya, sorry i didnt mention that, the starter goes engine spins everything is as it should be except the no compression part....
Thanks
. needed 10 posts for pm...
I tried it throttle open and closed, i have yet to pull the head off but I pulled the valve covers off and the exhaust valves are all stuck open slightly and all the intake valves are closed and in perfect condition, all the valves move, cams spin and its all timed correctly. Is it a common thing for an engine thats been sitting for 6 months or w.e it is to have valves stick for any possible reason, I want to leave pulling the head as my last resort assuming the exhaust valves are bent...
Thanks alot for your help :P
  • Like 1
  • 12 years later...
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
