Rb20det Running Bad.. :-(
regor
 Share
hey guys and girls...
i just got my rolla registed the other day wif a rb20det in it...
and i am now having issues..
i had a look on a few fourooms and could really find wat i am looking for..
this is my prob..
the car runs fine for the first 5 to 10 mins. then it turns bad and runs rough and rich...then stalls and is nearly imposible to start..
i pulled the plugs out and checked them, they wear all fowled up and driping wif fuel. so i put new 1's in and it fixed my prob.
i went for a lap around the block and buy the time i got back it was running rough and really rich again.. so i pulled my plugs out and the wear black and dripping wif fuel again.
i thought i had coil pack problem..i pulled 1 of then put it back on then the next 1... ect.. and found i had 2 dodgy 1's,
so brought new set and replaced all of them..and also cleaned my plugs and put them back in again... and went for another lap.. and then same prob again...
i also pulled the plug of my afm and the car stalls pretty much straight away, is that normal.
i also adjusted my cas abit an no changes still same thing...
wat could make it run so rich it would fowel my plugs up so quickly??
anyone no wat it could be...or can someone put me onto a link to help me out..
anythings i can check??
i am outta idears
cheers roger
p.s sorry for spelling and shit...
spark plugs dripping with fuel!!! i think that could be part of your answer,
maby you have a leaky injector, how ever small and is over fueling, causing the running rich. To much air and not enoughtful.
i would pull your injectors out get em cleaned and checked and if you put em back in out new o ring's in.
ok thanks for the help guys...
i will try afm outta my mates line hopefully morrow...
my cas i only couple months old..but will try my old 1 jut in case..
water temp sender ?? hmmm intreasting..
yeah i pulled my injectors out and got them tested and new o rongs went in...
is there another way i can check for cooler pipe leaks...(like spraying something on them)
thanks for the reply guys... :-)
 Share
    • Luckily I haven’t bought one yet but I’ve had several people tell me different things and was trying to find out what’s going on with my car lol apparently type m had different lover knuckles like the gtr but someone put non type m knuckles on mine Ok on another topic does anyone have a spindle for sale mine is screwed bad lmao
    • The vendor you bought from is a dickhead who can't tell the difference between AWD and RWD bearings. Their eBay listing is one of the first hits too, and is wrong. Any other hit shows the ones that are on your car. A search for GTR rear wheel bearings, unsurprisingly, finds the one you have from Shift. f**king muppets.
    • Got the flat door cards "good enough" for now. After cutting out the arm rest I removed all the stock trim material. Then filled the gap with a bit of Masonite and wrapped it in some adhesive foam to hide the  transitions as much as possible. Then I applied some black vinyl material to the panel with some spray on contact adhesive smoothing the edges as best as I could. Here is how it sits in the car with the door handle and cut down window switch mounted
    • Ok so I have a little bit of an issue. So I have a 1992 r32gtst and trying to replace the rear wheel bearing and spindle the research I’ve done shows a different style bearing than what is currently on my car. So the picture of the new bearing with the box says it’s the correct bearing as does my research but the picture shown of the old bearing is the one that came off the car. I’m a bit confused the new bearing has an ear on it that I’m assuming goes to where the top of the ebrake shoes mount as to where my old bearing does not. Any help would be awesome
    • What in the absolute mind f**k. Generally speaking, you cannot diesel a petrol engine without sparkplugs which you don't have since you're disconnecting battery.... Something is very fishy here.
