I am looking at getting an engagement ring for the misses in in the near future and was wondering if any of the NSW crew either work at a Jewellers or have good experience with any in the Sydney region...???
Cheers Guys.
https://www.sau.com.au/forums/topic/331697-jewellers/
You might save some moolah and end up with a larger stone if you go with a 'manufacturing jeweller'.
The guy that made my diamond wedding ring and my wife's engagement ring is one such person.
If you'd like to contact him, his name is Lanman Cheong (Lanman's Fine Jewellery) 02-9542 3222 and tell him Terry sent you if you like.
He won a De Beer's Award once, in his heyday. He used to make rings for Bruce & Walsh.
He works from home these days and if you see him, he lives on a modest waterfront property at Prince Edward Dr Woronora
Hint:- you and your fiancee might take a pic of your favourite design in a store, grab details of the stone with specs on the 3x Cs (carat , colour, clarity) and go with a budget in mind to the manufacturing jeweller like above - and state that this is your limit; so "what can we get with that amount of money?"
Hope this helps...
https://www.sau.com.au/forums/topic/331697-jewellers/#findComment-5382645
Cheers Terry!
I have been thinking of doing this with a local jeweller. Problem is at the moment I dont know what I want apart from its meant to be a suprise for the misses...
I am really looking forward to meeting you at the 21st bday cruise!
https://www.sau.com.au/forums/topic/331697-jewellers/#findComment-5382669
One of my friends took his turbo to a jeweler and said make this for my wedding ring.
Its a perfect replica and the turbine wheel even spins lol
I think it was $1200 from memory. Ill try and get the name of the place that did it.
https://www.sau.com.au/forums/topic/331697-jewellers/#findComment-5386332
Highly recomend jordans jewelers in Sydney cbd on market st, i got my missues her ring there, it works out well that i know the people there, but the process is too easy they guide you through every step of the way and work with your budget to make a ring thats unique, i chose three ring designs and got them to make one from the parts that i liked, see either Joy or Ari and say that Eddie recomended you.
best of luck with it mate, my missus loved the ring.
https://www.sau.com.au/forums/topic/331697-jewellers/#findComment-5386619
Wait what?! He has a miniture turbine on his wedding ring? Am I reading that right? lol
https://www.sau.com.au/forums/topic/331697-jewellers/#findComment-5386804
Yeah I did a double take (read) on that one too! THanks for all the input guys... I am most likely either going to head down the antique route or have one made like many have suggested... Now to continuesaving the pennies...
https://www.sau.com.au/forums/topic/331697-jewellers/#findComment-5388245
    • As a general rule removing rubber fuel hose is so difficult I would replace it if it hasn't been done in the last 5 years. The risk you damage the liner or one of the inner layers is pretty high if it's not almost brand new. BMW's recommendations around coolant hoses is similar. My R33's fuel hoses at the fuel tank were so perished that they were ready to burst FYI.
    • Ah yep, will do. Cheers!
    • Yes. It's either "2 wires", or 1 wire, depending on how you look at it. It is the connection that ties the battery -ve to both the chassis and the engine. Every electron that goes in or out of the battery goes through those 2 small spots (on the inner guard and on the engine block). If those are not clean and tight, then shit starts to suffer. Yeah, but measure it again cold in the morning, after it has had hours to rest. You can't usefully test the charge state of a battery immediately after it has been running because the alternator puts a surface charge onto the plates that takes a while to soak in and balance out. It will always read higher, and potentially look properly healthy, when fresh off of charge. But hours later it can look a lot less healthy. It's also worth measuring the battery voltage while cranking, although this can be difficult with a typical DMM because the screem update rate is so slow on most of them. An analogue voltmeter is actually a better tool for that. If the voltage drops too far while cranking, it is a sign of a poor battery. Although I don't think we're necessarily looking for a weak battery here - just wanting to exclude it.
    • https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.  Discounted tickets 20% off for their various tickets until the 3rd of Feb Monday. Drags, show and shine etc.  I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.  I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.  https://gtrfestival.com.au
    • Does have series 2 airbag steering wheel and passenger side airbag also.
