Want to install my monster tacho, but am unsure of the wires, looked @ the Autometer site but they dont have it!
Problem is i bought the tacho off my bro in law and he had it prof. installed in his car, and doesnt have the wiring diagrams/codes.
So im after some help on the colours of the wires coming from the tacho!
Like what each colour represents!
theres four: red, white, green and brown
power, illumination, ground and revs?
but what colour does what!
Any help would b great!
Cheers
https://www.sau.com.au/forums/topic/33171-tacho-wiring-diagram-plz/
you dont need to wire it up to the coils, just tap into the rpm signal off the ecu. there are a few diagrams of the ecu layout on these forums; just do a search.
also, i think to correct steve i think green is for the rpm signal, and white is for the illumination. It is better to tap into your dashlight wire because it you can adjust the brightness of it with the switch.
Did you look through this page?
http://hp.autometer.com/instruction_downlo...achometers.html
I can't imagine the tacho wiring to be different throughout their model range anyway :D
  • 3 weeks later...
anyone have problems with the signal to the tacho? i've wired it up correctly but get no responce from the ECU?? when i turn on the power the needle goes to 0rpm but when the engine is running the rpm sits at 3000rpm and just stays there???
  • 3 years later...
iv put tachos in many times, autometer being the easiest... best way to do it would be to take the cluster out and pull the plug out from behind the RPMs and then start the car and put the wires on the pins on the back of the plugs until you pick up the tacho signal, then splice or solder into wire behind the pin... thats what i did for my girlfriends lancer...
also if the signal doesnt read accurate check your earth wire, make sure its secure, a weak earth will make it inaccurate. better earth more accurate. test light will aid you
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I though you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
