Hmm this might be something worth looking into, yesterday morning I saw two cop cars making a huge scene over a 300ZX a street away from where I live. Two guys with torches one in plain clothes and thongs going nuts under the bonnet. Didn't see much other than a exhaust so not sure why they were making a big deal.
So whats the go with a eng certif? Can you still get defected at all?
Threads been deleted by site admin. Sorry guys, out of my hands.
who are the site admins???
Anyways i thought the group buy wouldve been good idea...
Obiously to some its not...
So who was going to do the engineering?
Id like to do mine when its back on the road
an engineers report wont stop you getting defected but if you have one and produce it when pulled over we find that 8 out of 10 they will leave you alone. alot comes down to your attitude but if a cop see's that your trying to do the right thing they usually leave you alone. As for epa . they are not concerned about engineers reports but only the pollution side of cars. they dont like pod fillter covers or homemade air box's front mounts or external bov. they will however leave you alone if you have had a recent emission test and passed.
AND if you did get a defect you would probably be able to follow that up with a complaint. You could even politely ask the officer on what grounds he was defecting you and if they weren't able to offer a reasonable case for it, you could suggest that you will make a complaint.... Of course, you need to be careful if you're going to play hardball.
correct me if im wrong but all an engineers report does is tell who ever is looking at it that its all done in a safe and propper way, doesnt change that mods on the cars are illegal.
anyway most times u get sent to the epa so paying for an engineers report wil do sweet f.a for you
Safe and proper means legal.
If you get the emmisions certificate done, it states that your car already meets emmisions which means a big waste of time to send you there again to be tested.
After I got my eng cert I never even got any more "random pullovers"
... without sounding too much like a complete idiot but wouldnt getting pulled over & not getting defected be as simple as not having anything to defect on, in or under your car ?? ...
... am i just getting old but who wants to have an unsafe, illegal, dodgy car that could potentially hurt you or even worse hurt someone else ?? ...
... having enough brains to hold a drivers licence should qualify you with enough intelligence to equip your car in a 100% roadworthy, legal & safe manner ...
... if it aint then dont drive it till it is ...
... not driving it while its being properly equipped will absolutely guarantee you wont get defected !! ...
... just as i thought - simple !! ... :) ...
Matt, a big waste of who's time exactly? Not the officer's, but yours.
Don't get me wrong, the report, and having it lodged against your registration helps, particularly when Police are following you, running your plates, and preparing to pull you over, but they are not stupid, and put plainly, engineers report or not, if they suspect that your car is too loud or may not meet the emissions standard, then they can issue you with a notice at their discretion.
Engineers reports have always been fairly easy to come by, and the old 'remove mods or detune to meet the standards and get the report then replace them' trick is something they are well aware of.
I think its important that others aren't reading this thread thinking that getting this done will guarantee defect immunity.
Engineering isn't just about 'safe', its about achieving FULL compliance with the ADR's and regulations that apply to your particular vehicle.
Illegal mods cannot be legitimately engineered.
There are however 2 classes of permissible modifications, owner certified (minor) or engineer certified, the later being where provided a qualified engineer signs off to say that the modifications don't contravene ADR's and your vehicle still meets the standards.
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
