Hey guys,
I had an attempt at installing my Sparco Torino II racing seats in my R34 the other day, and discovered it is going to be a very tricky process. The Sparco's have universal rails (I contacted Sparco and apparently they don't make specific rails, they only do universals), which of course are not going to be perfect. But I found my original R34 seats are mounted on little feet that are 'bolted' onto the rails of the seats and then the feet are 'bolted' to the floor. I say 'bolted' for lack of a better description, the fastening that attaches the feet to the rails is very strange, can't be undone by a tool. It is sort of like a pop-rivet style fixing... I can upload pictures if anyone thinks it will help.
Basically I want to ask if anyone has installed some seats in their R34 before, either with universal rails or specific rails, and how you overcame this problem if you encountered it? These are really nice seats, it would be a huge shame to not have them fit just because of these little mounts.
Thanks in advance for any help,
Martin.
https://www.sau.com.au/forums/topic/331753-installing-sparco-seats/
You'll need specific rails for your car. In your case, 34GTT rails as 32/33 rails won't work with RWD 34's.
The universal rails are there for you to modify to fit your application, which sometimes isn't the best/safest/easiest option.
Try and find someone who has a set of bride/recaro rails lying around and have a test to see if they fit sparco's. If so, you can source rails from those brands :ermm:
Was considering drilling out rivets ^ But I'm not sure if the feet will line up with the holes... And then I've f**ked my original seats? :)
What's my cheapest option here? Bride rails are like $315 each, that's ridiculous :(
I had to look, the Torinos aren't side mount. Besides finding a specific rail made for that seat to go in that car there aren't alot of options. Side mount seats are better because generally if you can find a rail made for your car you can use it with your seat. Good luck. I had a bottom mount sparco a couple year ago for an S2000 and came to the same situation you are in. My option was to sell the seat and find something better suited.
Sliders as in the universal rails?
How would I know what rails to buy though, wouldn't they be different widths and things so they might fit my car but not the seat? Bride rails are out of the question unless I can get some second hand ones for cheap, I'm not spending 700 bucks on a pair of rails, that's stupid.
Sliders and rails are different.
The slider is what makes the seat slide back and forth for adjustment.
The rail is what the car and seat are connected to.
Most rails have sliders built in. And most seats have a slider already bolted to them.
A universal rail still needs to be vehicle specific, as the universal bit is for the many types of seat out there.
So buy a universal rail to suit your car and drill new holes to match the seats.
you can buy drift branded bases (rail) from autobarnz. they make em for all kinds of cars.
this is just the base without sliders. i have a driver and passenger base in my car, didnt mount the sliders.
bolted the seat straight into the base, real low :)
Yeh I definitely want the sliders though
Hey Mate, I bought a pair of Recaro seat rails that also fit Bride seats, but I am about to buy R34 GTR interior so I will not be needing the rails, not sure if will help you out, but if you are interested send me a PM and I can send you some pics and send through some measurements etc...
Just to let you know these rails came out of a R34 GTT
P
bolted the seat straight into the base, real low :D
How much are they?
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
