Installing Sparco Seats
By soviet_merlin · Posted
I'm with Kinkstaah on this one. Do it once, do it right. So much better for your mental health. The sneaky thing about the fuel pump wiring is that it will work perfectly fine for the longest time. Until that one moment when it decides to shit the bed. And it's not worth the paranoia from not trusting the car anymore. At least other mechanical issues announce themselves by developing some noise or other warning. If you have the funds, I'd suggest to go with a good kit like Frenchys and get the work done by a trustworthy shop. No regrets there. The only downside to the Frenchys kit on the Stagea/R32 GTR is that their fuel level sender is not on point. But looks like the R33 kit maintains the factory sender so should not be an issue. This is what the botched setup on my Stagea looked like before it stopped working. It had melted its way quite a distance down. Glad it didn't burn down the car. Some links I came across when I looked for solutions: Radium sells a DIY wiring kit that looks promising. I didn't buy it though, I let my workshop decide on wiring. https://www.prospeedracing.com.au/products/radium-diy-fuel-pump-hard-wiring-kit-17-0031 https://www.radiumauto.com/DIY-Fuel-Pump-Wiring-Kit-P368.aspx You can also get cheap replacements for the locking ring depending on how mangled it looks: https://www.kudosmotorsports.com/Nissan-17343-79900-Fuel-Tank-Outlet-Locking-Ring-for-Nissan-S14-S15-BNR32-R33-R34-AWC34 There are tools for unscrewing it as well so you don't have to abuse it with a screwdriver and mallet. The Frenchys one is expensive but I'm sure there are cheaper ones. -
EOFY SALE Dropped to $1000.00
Hopefully not shockproof. It does crappy things to good synchros.
