meshmesh Posted January 30, 2004 Share Posted January 30, 2004 Ideally it would be nice if this thread could become the be all & end all of GTR CLUTCH Solutions... So here's hoping. After doing a search resulting in some 166posts dating back when Australia was founded, & yet no real solution, I post this hoping for a simple solution for all. My problem is finding a clutch for the R33 GTR, apparantley some model 33 gtr are similar to 32gtr & then some 33 clutch work with 34's, some are push & some are pull.. WTF is the difference? Some say push is cheaper than pull, Nismo Clutches are straight fitting, OS Clutches need modifications.. who knows. Heres a table, maybe someone can fill in the blanks.. (please state whether it's push, pull, twin, triple, ceramic, whatever else you can think of) R32 - <200rwkw R32 - <300rwkw R32 - <450rwkw R33 - <200rwkw R33 - <300rwkw R33 - <450rwkw R34 - <200rwkw R34 - <300rwkw R34 - <450rwkw Also: What clutches fit what models? eg: does the 32 fit a 33? or a 33 fit a 34? Thanks meshmesh Link to comment https://www.sau.com.au/forums/topic/33176-clutches-gtr-push-or-pull-twin-or-triple/ Share on other sites More sharing options...
benjiman74 Posted January 30, 2004 Share Posted January 30, 2004 the clutch fiited to r32 gtr from 89 - 92 is the pull type. R32 93+, r33 & r34 gtr all run the push type clutch. Link to comment https://www.sau.com.au/forums/topic/33176-clutches-gtr-push-or-pull-twin-or-triple/#findComment-665281 Share on other sites More sharing options...
Don Cornelius Posted January 30, 2004 Share Posted January 30, 2004 Err, no... 8/89 to 2/93 push clutch fitted to 32 2/93 to 12/94 pull clutch fitted to 32 All R33s are push R34s are pull. To fit a decent tripple you need a push clutch Link to comment https://www.sau.com.au/forums/topic/33176-clutches-gtr-push-or-pull-twin-or-triple/#findComment-665318 Share on other sites More sharing options...
Jay95R33 Posted January 30, 2004 Share Posted January 30, 2004 I can confirm that a 94 R32 GTR is a pull type. And this pull type on a 94 R32 GTR is different to a R34 pull type. (the R34 GTR pull type is about 10mm higher). J Link to comment https://www.sau.com.au/forums/topic/33176-clutches-gtr-push-or-pull-twin-or-triple/#findComment-665515 Share on other sites More sharing options...
Merli Posted January 30, 2004 Share Posted January 30, 2004 With the exception of Jay's post, everything else has errors in it. Let me post from my NISMO catalog that lists exactly what they are. BNR32 (Start ~ 2/93) - PUSH BNR32 (2/93 ~ End) - PULL BCNR33 - PULL BNR34 - PULL (But incompatible to non BNR34s for reasons stated in Jay's Post) Link to comment https://www.sau.com.au/forums/topic/33176-clutches-gtr-push-or-pull-twin-or-triple/#findComment-665583 Share on other sites More sharing options...
ylwgtr2 Posted January 30, 2004 Share Posted January 30, 2004 yes yes...i concurr with jay!!!Prob for the same reasons!! Link to comment https://www.sau.com.au/forums/topic/33176-clutches-gtr-push-or-pull-twin-or-triple/#findComment-665624 Share on other sites More sharing options...
ed Posted January 30, 2004 Share Posted January 30, 2004 ER34's are Pull too...can you confirm that Merli? Also is there a benefit pull over push or push over pull? Link to comment https://www.sau.com.au/forums/topic/33176-clutches-gtr-push-or-pull-twin-or-triple/#findComment-665645 Share on other sites More sharing options...
Merli Posted January 30, 2004 Share Posted January 30, 2004 ER34's are Pull too...can you confirm that Merli?Also is there a benefit pull over push or push over pull? ER34s use PULL clutches, and are the same as the (2/93 ~ End) BNR32/BCNR33 PULL clutches. Not sure what advantage there is of one over the other, but I know that OS Giken only make PUSH clutches and I had to buy the OS Giken Conversion kit to adapt their clutch for my BCNR33.... From that I assume (probably incorrectly) that PUSH clutches are better? Link to comment https://www.sau.com.au/forums/topic/33176-clutches-gtr-push-or-pull-twin-or-triple/#findComment-665666 Share on other sites More sharing options...
ylwgtr2 Posted January 30, 2004 Share Posted January 30, 2004 push type clutchs are better for high horsepower applications....i hear you can get more clamping pressure out of a push type clutch Link to comment https://www.sau.com.au/forums/topic/33176-clutches-gtr-push-or-pull-twin-or-triple/#findComment-665670 Share on other sites More sharing options...
ed Posted January 30, 2004 Share Posted January 30, 2004 Thanks for confirming that Merli. ylwgtr2, yeah I was thinking about that, more of a clamping force can be applied? Link to comment https://www.sau.com.au/forums/topic/33176-clutches-gtr-push-or-pull-twin-or-triple/#findComment-665683 Share on other sites More sharing options...
Don Cornelius Posted January 30, 2004 Share Posted January 30, 2004 DAmn, i came on to correct what i said, but Merli has said it all perfectly, nice one And yea, push clutches are far better for big HP applications Link to comment https://www.sau.com.au/forums/topic/33176-clutches-gtr-push-or-pull-twin-or-triple/#findComment-666779 Share on other sites More sharing options...
NRB Posted January 30, 2004 Share Posted January 30, 2004 Can someone explain the difference in a push and a pull clutch? I assume the slave cylinder is mounted with the piston facing forward in a pull type and rearward in a push type... Link to comment https://www.sau.com.au/forums/topic/33176-clutches-gtr-push-or-pull-twin-or-triple/#findComment-666799 Share on other sites More sharing options...
Jay95R33 Posted January 30, 2004 Share Posted January 30, 2004 Can someone explain the difference in a push and a pull clutch? I assume the slave cylinder is mounted with the piston facing forward in a pull type and rearward in a push type... Yepp, that's it. Plus when you see the pressure plate you'll see the difference. With a push type, when you push the clutch peddal in, the thrust bearing 'pushes' on the pressure plate splines which disengages the clutch. With a pull type, as you said, the slave cylinder is facing the other way around, and when you push the clutch peddal in the thrust bearing 'pulls' the pressure plate out (the thrust bearing is actually clipped into the pressure plate splines) to disengage it. Here's some pics to show you the difference. J Link to comment https://www.sau.com.au/forums/topic/33176-clutches-gtr-push-or-pull-twin-or-triple/#findComment-666808 Share on other sites More sharing options...
vspecv Posted January 31, 2004 Share Posted January 31, 2004 merli is spot on. manufatures generally go for pull type as it is easier on the foot,and can use higher clamping loads without increasing the heavieness at the pedal, but not ideal for high hp appliactions Link to comment https://www.sau.com.au/forums/topic/33176-clutches-gtr-push-or-pull-twin-or-triple/#findComment-667095 Share on other sites More sharing options...
