BKR6EIX-11 or something like that
Spot on
i think all NGK are iridium?
Neg, Standard plug is nickel - the ix in the code above stands for iridium. A nickel plug would be BKR6E-11 or BKR6ES-11 (S is for standrard) the BK is thread type and is the same as BCPR6ES-11.
There is no performance gain, usually better off with normal nickels unless you are after less frequent plug changes (which isn’t recommended for performance anyway). The plugs on RB's are easy to get to, so there is no reason you wouldn’t want frequent changes, but each to their own.
Your better off spending your money on higher quality oil, like fully synthetic 5w-50 (if you dont already) or saving it for actual performance mods.
https://www.sau.com.au/forums/topic/331782-spark-plugs/#findComment-5383958
pretty sure the ngk are coppers, not nickels. the bcpr6es-11 and bkr6es-11 are copper plugs gapped at 1.1, if the op is interested. both are fine, the bcpr is slightly longer so goes further into the coilpack.
iridiums have a wide variety of success, from lasting less than coppers to actually lasting many tens of thousands of km. have a look in the spark plugs thread.
also, on oil, most people find a 10w40 the best oil for an rb engine. a w50 is very heavy, but that's much worse for turbo'd cars. either a 5w or 10w is fine, as long as it's a good mineral semisynthetic or a full synthetic, and changed every 5000 km (or at most 10000km for na). have a look in the oil thread for more info
Edited by Galois
https://www.sau.com.au/forums/topic/331782-spark-plugs/#findComment-5385282
Nickels just get called coppers, all spark plugs have a copper core but copper its self cannot handle the combustion temperature and pressure's - if it did, then it would be BY FAR the most superior conducting spark plug type.
http://environmentalchemistry.com/yogi/per...electrical.html (read bottom up)
Oil is a personal preference. If your car is ever driven hard, you are stupid to have anything but a full synthetic oil. I am very particular with oils and monitor my oil gauge pressures and temperatures carefully.
While yes, on an N/A 50w might be a bit excessive (with 40w being better) I would never run any thinner than a 50w, even with a decent full synthetic 50w oil (Mobil1) after a thrash my oil gets dangerously thin. Oils any thinner or any lower quality (nulon 100% synthetic for example, even in a 50w, once hot is pathetic).
My engine is turbo though, but is in a cooler climate. The oil still got very thin on long run summer days (when N/A).
I would never go a 10w40, would rather Mobil1 0w/40 (but at a zillion dollars), why would you want a thicker cold start... It’s already off the charts in pressure at my 5w.
https://www.sau.com.au/forums/topic/331782-spark-plugs/#findComment-5385450
yeah i get the conductivity side, i always just thought it was a copper alloy.
I would never go a 10w40, would rather Mobil1 0w/40 (but at a zillion dollars), why would you want a thicker cold start... It's already off the charts in pressure at my 5w.
nissan says run a 7.5w30, but that's in japan where it's slightly cooler, and for when the car is new.
the thinner the oil the more wear it allows, that's why people vary between 0w and 10w.
the general guide for oil is use a w40, based on all the testimonies in the oils thread about cars running badly on w50. it's a balance between getting fresh oil constantly to all parts of the engine/turbo and making sure once it gets there it's think enough to provide adequate lubrication.
when you say dangerously thin, is this something you've observed, like hearing the lifters or something?
https://www.sau.com.au/forums/topic/331782-spark-plugs/#findComment-5385788
It's something I’ve observed from oil pressure & temp gauges.
When cold it sits perfectly on 3/4, at temp on idle it’s at 1/4 and with revs/load it’s just under halfway.
And as the temps climb those pressures remain constant, only lowers once the oil is due for replacement (~ 5000k's). Mineral oils are pathetic, consistently get thinner with heat, and I’ve found nulon 10w/50 '100% synthetic' and another synthetic I’ve used (19=0w/40) is far too thick on startup (nearly max on the gauge) and way too thin with any heat (~1/8th on gauge at idle, 1/4 with load/revs).
Oil in an N/A will get hotter than in a det though, as they don’t have the water flowing through the filter point, among other reasons.
So yeah a 40w might be a good option, I’m just quite pedantic (having done bearings before) and like my pressures perfect (and watch them closely). BMW M series engines for example run 10w60 (Castrol RS), for the same reasons I run the thicker oil.
I have noticed no performance drop, and it’s worth it for peace of mind.
Anyway, not an oil thread >_<
If you check ngk's website they do say a nickel alloy for there standard plugs http://ngk.com.au/sparkplug.php.
https://www.sau.com.au/forums/topic/331782-spark-plugs/#findComment-5386448
It's something I've observed from oil pressure & temp gauges.
When cold it sits perfectly on 3/4, at temp on idle it's at 1/4 and with revs/load it's just under halfway.
And as the temps climb those pressures remain constant, only lowers once the oil is due for replacement (~ 5000k's). Mineral oils are pathetic, consistently get thinner with heat, and I've found nulon 10w/50 '100% synthetic' and another synthetic I've used (19=0w/40) is far too thick on startup (nearly max on the gauge) and way too thin with any heat (~1/8th on gauge at idle, 1/4 with load/revs).
Oil in an N/A will get hotter than in a det though, as they don't have the water flowing through the filter point, among other reasons.
So yeah a 40w might be a good option, I'm just quite pedantic (having done bearings before) and like my pressures perfect (and watch them closely). BMW M series engines for example run 10w60 (Castrol RS), for the same reasons I run the thicker oil.
I have noticed no performance drop, and it's worth it for peace of mind.
Anyway, not an oil thread :P
yeah, not an oil thread, sorry for the diversion...
skit, are you using the stock pressure gauge? people reckon they're pretty unreliable.
that said, I do watch the pressure, tends to let me know if anything's wrong, when it's ok to give the car a squirt etc... but for less satisfied people, many of which are in the oils thread posted below, the w50 was a mistake. someone said quite a while ago that it didn't provide adequate lubrication for the turbo at temperature.
http://www.skylinesaustralia.com/forums/Go...&start=1640
anyways, oils seem to vary HEAPS for different cars, which is no surprise seeing as many of them have done over 100k kms plus whatever was taken off when they came over
https://www.sau.com.au/forums/topic/331782-spark-plugs/#findComment-5389872
    • No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
