Honda Car Club Skid Circuit Day, Eastern Creek 21/03/04
The Honda Car Club of NSW Inc. are holding a Drift Day on the Skid Circuit (figure 8 track) on Sunday March 21, 2004.
If you are interested in attending please contact Kevin San, [email protected] or go to http://hccnsw.org.au/
Cost: $80.00
A CAMS License (L2NS minimum) is required and can be arranged through the Honda Club on the day for:
$20 for a 1 day license, or
$45 for an annual.
If you are a financial member of SAU NSW we can issue you with an annual license. If you intend to do ANY speed events later in the year I would say a L2S ($91.00/year) is the best license to get. (This exceeds the L2NS license).
  • Replies 46
Yup, to ensure that everyone gets a decent go, we're limiting numbers to 33 for the day. Entry form can be found at:
http://www.aus-cartalk.com/ads/SkidCircuitDayAd.htm
...shoot me an email at [email protected] (gee, I wonder what Skyline I had? :( ) if you need info.
This is the day after the amanda's cruise!!! Should be a hot weekend!
eh? which month is amanda's cruise?
I'll try to be along but can't commit at this stage. Hope there's still spots
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
    • I thought about ditching it but I was worried my bonnet would sound like a 90's Swift GTi sub-filled boot.
