i want to drop my r34 (with the standard bodykit) and i want to keep my ride quality as much as possible as im not worried about going fast around corners or anything so would lower springs be the way to go? maybe some do's and don't, brands and prices will help.
p.s i am tying to limit how much i spend so money saving suggestions would be great!!
https://www.sau.com.au/forums/topic/331808-best-way-to-lower-an-r34-gtt/
get lowwer springs but your ride will change as if you are going to lower your car uou will need stiffer springs to compensate for the redused up/down travel .
another option if you know of a work shop that specializes in leaf suspention (usualy found in 4X4 mags) they can heat and compress your springs slightly to lower your car.
DONT cut the springs !!!!! hit a bump or get airborn and your spring will fall out (been there done that )
Lowered springs (King Springs, Pedders, Lovells) on standard shocks is probably the cheapest option.
- Pros: Cheap, looks ok (if that's what you're after)
- Cons: Increased wear and likelyhood of failure on shocks, worse handling, etc.
Read SydneyKid's Lowering Springs With Standard Shocks thread for some more info.
  • 3 months later...
glowstreet the gt-r shocks wont fit im quite sure, i have a set at the moment that i got off a friend for free, took em to a mechanic and asked if it would fit and i found that the front 2 will fit, but the rear 2 will not
On a GTT it will fit all the way round. on a GT or a 33 GTST it won't fit the rears. The fronts are also a lot lower but the rears will be same height
Whilst it might fit, everything I've read says it will be entirely the wrong spring rates, etc for the car. Apparently the GTR weight distribution is quite different to the GTT (4WD system, engine differences etc). This information has been posted around the forums a few times by people in the know...
    • Just get the magnet out... I can think of 37 different options to get it out without removing the pan. 4-5x of those options are already mentioned here. I personally would drill a larger hole in the pan, pull the magnet out and then block the hole with another magnet. Then reuse another magnetic oil plug. The more magnets the better.
    • How f**ked am i? what would happen if i leave the magnet inside there?
    • I'll update you guys when i get home from work, im going to try to fish it out.  I just realized that i can't even drop the oil pan. The whole front diff and axles are connected to the oil pan... is it even possible to drop the oil pan without taking out the motor?
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
