hey all, i want to check my CAS timing, and have no idea how to, nor do i have the tools, does anyone in the SE have the tools and know what to do? and know your shit regarding them? as they can be fatal if not done correctly!
cheers
https://www.sau.com.au/forums/topic/331820-anyone-in-the-se-know-cas-timing/
goto autobarn and buy a timing light
thats all you need
once engine is warm and running use the timing light (it will come with instructions) to read base timing
for rb25 it should be bang on 15deg. if you get any other number, your CAS is offset and must be adjusted
when i say offset, as in, it is dialed forward or backward. at idle, the timing is locked so for rb25 it is always 15deg
so if your timing light said say 12deg, then this means your entire tune is 3deg off, which means it will be sluggish
the ECU assumes your timing is bang on as per the CAS and won't know if its offset (ie backdialed/forward)
once you adjust, run a check with timing light and keep going until you get to 15deg at idle
thats all you need
ok, i guess ill give it a try.
if say its off by 3 degrees, how do i know which way to turn the cas to correct it? im assuming just so the bolts are center of the holes?
no idea, someone on here would know how to use a timing light on RB25
surely it can't be hard ? the timing light will tell you what timing you have at idle
it should be 15deg for rb25. so if at idle the timing light tells you any other number than 15, your cas needs to be adjusted
ok, cheers mate, hopefuly someone has a read of this thread and posts how to hook the lines into the spark plugs
The timing light comes with a spark plug socket and also a clip which can be clipped to a specific wire. On the rb25 at the back of the block where the coil pack wire harness is you should see a white wire I think sticking out you clip the light to that.
depends on what timing light you get, the crap one usually can only pick up the signal from HT lead which you don't have in RB25 so what I normally do if I have to use bottom of the range timing light, I undo the No.1 coil pack with 8mm socket which is the first one you see when you open the bonnet. then connect the spark lead between the coil pack and spark plug then. Fron there you can clip the timing light signal pick up to the lead and connect 12v
ok will do
so does the timing light say as a figure what degree its out?
and how do you connect them to the plug if it has coilpacks? they are completely enclosed :S
Hook it up as Panko described (you can get a short spark lead when you get the timing light).
You read the timing on the crank pulley (big one down the bottom of the front of the engine). There is a set of 7 marks at 5 deg increments, which move from driver side to passenger side (L->R as you stand looking into the engine bay). The last mark (left-most) is TDC (Top Dead Centre). Each time the coil fires on the #1 cylinder, the timing light will flash its light. The flash will "stop" the crank pulley so you can read which mark is aligned with the pointer located on the crank case cover. You want 15 deg BTDC (Before TDC), which should be the 4th mark (from either end).
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
