Hi there
I am after some info on the apexi safc, like how much more power would u get out of using one and can u tune the car that much more with one with standard ecu. Sorry for my ignorance I dont understand them that much. I have the following mods if that helps.
Nissan Skyline1997 r33 s2
apexi airfilter
walbro fuel pump
large front mount
dump 3in exhaust
splitfire coilpacks
atomic boost controller running 10psi
bov
with standard turbo
thanks
https://www.sau.com.au/forums/topic/331866-apexi-safc/
not sure how much power you have now but with a SAFC you can tune the air/fuel and net 250-280rwhp
aorund 200 now? assuming you dont hit R&R
but if you plan for more mods in the future then get a stand alone ecu which can control ignition timing would be better
https://www.sau.com.au/forums/topic/331866-apexi-safc/#findComment-5384682
Hi there
apexi airfilter
walbro fuel pump
large front mount
dump 3in exhaust
splitfire coilpacks
bov
with standard turbo
thanks
Most cars with those mods will get between 180 to 200rwkws.
I got similar mods on my car minus the FMIC (only got a SMIC off a 34 GTT) & the coil packs (still on stock ones I think), I got 180rwkw when I got my SAFC 2 tuned at All star garage.
Also my car is a 4 speed slug auto box so theres more power loss at the transmission compared to manual.
https://www.sau.com.au/forums/topic/331866-apexi-safc/#findComment-5384734
i reckon something like a Nistune/Mines/Blitz tuned computer coupled with a SAFC is bomb, that way you have the more agro timing maps, and can still pull/put fuel where you need it!!!
why do you need safc when you have nistune?
Mines/Blitz are tuned in jap land and i dont think their suitable with aussie conditions
https://www.sau.com.au/forums/topic/331866-apexi-safc/#findComment-5385064
Hi there
apexi airfilter
walbro fuel pump
large front mount
dump 3in exhaust
splitfire coilpacks
bov
with standard turbo
thanks
I used to have an Apexi SAFC and an SITC (to control timing) and they worked reasonably well but I would recommend a Nistune chip which will give you much better tuning ability for about the same money. Nistune do not make a chip for the R33 so you will have to use an R32 ecu or other and chip that. Do some searching - there have been a few threads on this topic.
https://www.sau.com.au/forums/topic/331866-apexi-safc/#findComment-5386329
If you are ABSOLUTELY sure u are not going to do any more mods except raise the boost 1-2psi the safc will be the cheapest and best bet.
U may just get a few extra max kw but the good part is that you can tune out R&R with it and make the mid range come to life
I had an safc2 along with an adj fuel pressure reg and the exact same mods listed above on my 25 and the car felt so much better to drive without that hole in the mid range
https://www.sau.com.au/forums/topic/331866-apexi-safc/#findComment-5386372
True that ^
But then again it seems pointless. A Nistune board will cost much the same as a SAFC, perhaps a little bit more considering you need the R32 Or Z32 board for an R33. You need a tune on the Nistune or the SAFC, Nistune will be cheaper to tune because it will already have a base image for your car. And then the gains you will get from the Nistune far outweigh those of a SAFC...
https://www.sau.com.au/forums/topic/331866-apexi-safc/#findComment-5386539
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
    • I could see someone trying this to save money on oil changes.
