Hi Everyone,
Gauging intrest for a group buy on these ezitrak car tracking systems from rojone.
Price will be $820 inc gst for the unit, install instructions, owners manual, tracking software & $20 pre-paid sim
These units retail for $950+ gst, not including the sim.
http://www.rojone.com.au/bandit/ezitrak.html
Once this unit is installed, you have no more to pay (apart from credit that is used on the pre-paid mobile number). any auto sparky can install this unit for less than $100
Much better alternative to satnav etc, at a cheaper price, with more options and no monthly fees.
https://www.sau.com.au/forums/topic/33187-group-buy-ezitrack-tracking-system/
dude good work man, i cant justify the cost right now, but that is a really good price for the system you damn right
hopefully once the conversion is done, i will find a grand that i misplaced (fingers crossed)
13_devil: I am getting 1 in my skyline next week, I have checked out a demo unit in another car and was extremely impressed, it serves every purpose i would have hoped for
erik: there is software for tracking on maps, and you can also referance it to your UBD roadmap from the coords it gives you.
markr33: it works 100% independantly of your existing alarm, so it wont interfere
Once the group buy is done, I will still be stocking these items, but at the price of $950 + sim card
Even though sim card tracking is the easiest to recircumvent (by driving into an underground car park, an area with no reception or a mobile phone jammer set up), this is one of the best deals I've seen for a tracking system.
These things used to sell for about $2000 over a year ago when I bought my car, I was considering installing one then. There used to be a demo number you could call and see how it worked from your own phone *shrugs*
These things are great piece of mind! Sadly, I don't have $1k lying around just yet :(
a $20 pre-paid sim has $20 credit on it, it only needs to be recharged as you run out of credit, or every 6 months, they are with telstra (best mobile coverage)
If the car is stolen, you send the car a sms via the mob #, and it will instantly respond with location, current speed etc, and you can even send commands like immobilize, lock doors etc. you also get a sms/phone call when the car has been broken into and another if it gets started.
mike, software comes with it.
okay guys, heres how it will work: $50 deposit, the rest apon arrival (3-4 days). install is easy enough to do yourself if you know a little about electrics.
So, anyone in?. I wont be placing the order for about 2 weeks, but i need numbers.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
