some people are holders of said key :woot:
Manildra (Fueltown) E85 all the way baby! :laugh::)
I will prob use Caltex E85 in the warmer months, but only once Trent has had a check over it on the dyno with the fuel in. Even the variance between United and Fueltown needed a little tweaking.
But i reckon get something installed in the tank to monitor ethanol levels and get an ECU to modify accordingly (interpolate between two+ maps). Basically how the the flex-fuel cars work. Just need a good enough ecu i guess.
  • 1 year later...
  • Replies 68
How has this all progressed? Lots of loose ends, posting here for Googleability. Can't seem to find much info from the Google.
Where can I find current E85 prices?
How has the price/economy of it changed? (I don't drive currently so I don't know the prices)
Have any people noticed any ups and downs after an extra year of use?
Edited by jukic.j
So it's about 25c cheaper but about 30% more fuel is used unless I muddled that figure?
Don't forget to add 15% more HP into the equation.
Heard a rumour that United is going to equip more servos with E85. Any truth in that or is it simply just a rumour?
Would love to get the 33 on E85 full-time but the lack of nearby servos that stock it worries me lol
More, 50-70c
United E85 - 97c
BP98 - $1.60
$1.60? There do you fill up :O
I paid i think $1.45 the other day, might have been less. ULP on the usual good days has been ~$1.25 so it wasn't too much more.
hahahahah.... indeed.
Melbourne is quite spoilt for E85 outlets - United has quite a few now, it's a pity the Caltex roll-out seems to have stalled a bit though. Don't really care though, as you're better off running United anyway.
United in Scoresby has E85 that wasn't on the website last time i looked too.
Yeah I think I'm going to run E85 too, well at least look into it seriously. I'm pretty spoilt for choice with stations around me (Caltex and United).
Just not sure how much more efficient it'll be. Still I'm finding that I'm paying around 1.45-1.54 for ULP. Dunno where some
Of you blokes are getting those mint prices! :D
Where are you located? There's heaps of E85 servos around me
The 33 stays in Berwick most of the time but also keep it in Frankston occasionally too.
Only Uniteds I know of that stock around those two areas are Patto Lakes and Hallam :unsure:
Hallan close enough !!
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
