  • Replies 381
Posted Images
grippier tyres.....more track knowledge......hardest bit is the fact i dont want to manualise it
I was running plain street tyres. Some okay-ish Bridgestone items. Was also suffering misfire above 4,500rpm, so I had to shift gears early. But yeah it helps to know the track well :blink:
See how I go next time out.
^^ LOL gav
Nugzy I hear ya... my GTR was all over the place on street tyres out there... semis are a must for good times.
You weren't the only one I was just running 595 federals, I was in car 20 the Purple 31 coupe, only chang i made to the car from my drift set up was putting 235's on the back vs 215s all round.
Although I drove the car to 150% of the tires capabilities, the car was either sliding the front or the back or all the whole time. and I was not trying to drift it.
But I reckon a 126.99 and running consistently and being within half a second the whole day of that time with street tires and stock brakes, with the car sliding the whole time, even at 200km/h when clicking 5th at the kink, was pretty reasonable.
would have liked to go faster but need better tires and brakes
Was the suspension overly stiff at the rear? Will cause the rear end to slide far more than you want for a rwd car, obviously if you primarily drift then you don't want to change much but some softer rear rates and dampners would probably be of big benefit.
Running 32 rear sub frame rear spring rate is 7.5 kg JIC dampers non adjust valveing inverted mono tube, white line adj rear bar the thickest one 24mm from memory stiffest setting 17x9+35 wheels 1deg neg ds camber 1.5 ps camber .5mm toe in.
Front 31 struts converted to coil overs 8.1 kg springs bilstien inserts, (fells just slightly under damper 3 deg neg 2mm toe out 17x8 total offset +3 5deg castor (cant put any more in or ill hit the front bar) front bar whiteline 27mm adj on softest setting.
Haven't got around to plunging in all my geometry and settings into my full car dynamic modelling software yet but will get around to it shortly.
Was mainly having issues with slow-med speed under steer around tight corners and have almost fixed that, but it has obviously induced high speed over steer (with 200 only RwKw you should not be able to blaze the tires in 5th at 200).
but yeah Not too concerned just yet as the car is a drift car and those conditions are not encountered at mallala during drift
Well the speedo is not connected, and I over estimated. just calculated my speed from my tach, only hit 180Km/h.
6500 rpm 235/45R17 (643mm dia) 4.36 diff in 4th 1.1
didn't mean to BS, but it was very hairy having the ass step right out on you at that speed any way
it's tonnes of fun! right after you shit yourself
i think marc (GTS II) might have done that around the kink behind me at one point. i had a mirror full of opposite lock SVD :)
^^ LOL gav
I too had grip issues, both under brakes/cornering and coming on boost. And that was with 265 Toyos but admittedly being 18's really doesn't help.
Definitely going to get some 17's for track wheels and fit some semis.
http://justskylines.com/knowledgebase/widg...calculator.aspx
Great website for stuff like this
Edited by Rolls
no ones got pics of the red mx5? i see how it is, there's no love for the old miata :(
Yeah, i know, im well behind in getting pics up. Along with building my own cars, and working, i've been getting through pics, more later tonight... In the meantime, the MX5, creating a smokescreen to distract others...
And fighting well above its weight ;)
probably the classic 'oh shit oh shit oh shit OH SHIT!' face.
ha, guess my spoiler makes a bit of a difference through the kink, never had the back end feel like it wanted to dance off line.
i remember my thought proces quite well:
"okay here we go, 50 meter board, wait, wait, wait BBBBRRRRAAAAAAKKKKEEEEE, turn in......
shit, too much
catch it... hey check out this cool slide.... ah wel its gone too far, keep the power on and do a big skidOOOOHHHHHH SSSHHHHHIIIIIIIITTTTTT!!!!!!!!"
then a little bit of wee came out
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
