Hey guys decided to put a new post up because I cant put everything in the first post on my other thread. So here goes!
Item:
5 Speed manual gearbox, came out of my r32 GTS-T rb20det
Genuine K's: 86,000K's
Excellent condition!
Price: $800
Can Frieght at your expense
Item:
Set of 4 rims with brand new tyres, 1 tyre needs to be replaced. All 4 caps are there. They are 4 or 5 stud wheels.
17x7 Sparco Wheels
Rears 235/45 ZR 17
Fronts 215/45 R 17
Price: $800
Item:
Selling my brand new polished forward facing plenum. Come with semi polished XF Throttle body. Suits N/A runners, and you can use it with the stock ecu as it has the idle air control valve on the rear still.
Price: $400
Item:
R32 GTS-t Front rotors and 4 spot callipers
Genuine 86,000K's
Excellent condition
Price: $400
Item:
R32 GTS-t RB20det
Factory Dump Pipe to Cat, 2 piece.
Excellent condition
Price: $200
All prices are neg. Make an offer on all parts. Can also frieght any parts at your expense
If there is any parts you need from an Imported 1994 R32 GTS-t 2 Door Coupe Message me and see if I have it!
Located: Victoria
Contact details:
PM Me
[email protected]
Txt only 0448 644 653
Pics:
https://www.sau.com.au/forums/topic/331925-parts-for-sale/
take the plenum for 350 posted
gearbox take for 500 ono
rotors and callipers take for 300 ono
wheels take for 700 ono
dump take for 100
Edited by Nackerz
https://www.sau.com.au/forums/topic/331925-parts-for-sale/#findComment-5387743
gearbox take for $450
rotors and callipers take for $270 ono
wheels take for $600 ono
dump take for $80 both pieces
also have a mint condition drivers side skirt for 2 door $80
and mint condition manual tail shaft for 2 door $140 or take it with the gearbox for $550
https://www.sau.com.au/forums/topic/331925-parts-for-sale/#findComment-5390307
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
