After a lot of pain and little things that needed fixing here and there i have finished my custom amp install, i have relocated the battery and put the two amps next to each other on a slide out tray for configuration, etc.
Pics can be seen below
http://users.bigpond.net.au/skyliner33/amp...mp/DSC00012.jpg
http://users.bigpond.net.au/skyliner33/amp...mp/DSC00013.jpg
http://users.bigpond.net.au/skyliner33/amp...mp/DSC00014.jpg
http://users.bigpond.net.au/skyliner33/amp...mp/DSC00015.jpg
http://users.bigpond.net.au/skyliner33/amp...mp/DSC00016.jpg
http://users.bigpond.net.au/skyliner33/amp...mp/DSC00017.jpg
http://users.bigpond.net.au/skyliner33/amp...mp/DSC00018.jpg
I still have to secure the sub and sort out a bit of the wiring but other than that i am happy with the results.
Kris
https://www.sau.com.au/forums/topic/33193-custom-install-finished/
I ended up bolting my sub box into the boot after trying a few other methods of keeping it from sliding around.
What i did was bolt it to one of the existing holes in the boot floor. If you lift up the carpet in the boot you will see big cutout circles which are plugged with rubber plugs. If you lift one of those plugs out you see there if a big hole.
I built a bracket that bolts on to the back of the sub box and clamps onto one of those holes. I'd have to take photos to explain exactly. Ill do that tommorrow.
yeah thats true, except my sub is freely moving around the boot at the moment, the other stuff is not in the way, i am still yet to design and build an appropriate method of holding the sub in, not affecting the access to the spare tyre. I will think of something.
i wont have the pic for another 2 weeks chris, sorry bout that
my boot was simple tho, just 2 10" flush mounted facing up(in custom boxes), with the 2 amps in the middle kinda,
it looks good but the big problems are that i had to ditch the spair tyre (not that's its any good) and i have no boot space at all hahah but i don't cair, bass is more importaint!
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
    • Dashcams Australia (13/05/25) captured JDMHSE (Vic plate) being a right tosser.
    • Wish someone would start a racing series for Group A replica cars, a bit like Touring Car Masters but for 1985 onwards and not grandpa's falcon and/or Monaro. I know they race in some historic class but that's for original cars, no replicas allowed.
