i was just having a chat about f1's and racing and thought would it be possible to use liquid nitrogen to cool a engine with it having some sort of restrictive coating in the engine or some sort. So that it doesnt cool the metal enough to shatter.
cam
https://www.sau.com.au/forums/topic/331936-liquid-nitrogen-in-engines/
little bit of common sense required here
liquid LPG injection systems are available these days- as the LPG is port injected, it changes from a liquid to a vapour, and the change of state of the liquid to a low pressure gas results in a drop in temperature. this also sucks heat out of the combined intake charge in the inlet manifold (latent heat of evaporation). it turns into gas instantly
same would happen with liquid nitrogen. but it wouldn't benefit power, because nitrogen isn't combustible and would merely take up space that could be occupied by oxygen
the reason NOS gives a power increase is because its N20, and during combustion the oxygen molecules are stripped off the compound to massively aid the combustion of the incoming fuel/air charge
sorry if the original post has come across wrong, but i was asking if it could be used to cool the engine not used as a fuel. When i mentioned f1's its purely because they dont have radiators and was thinking if this could be a substitute in any vehicle
who told you F1 cars don't have radiators?
as Mikey Mike said- they do (1 in each sidepod), and they cost ~$50k each
methanol drag cars don't usually have radiators, because the fuel burns very cold, and the cars are only usually running for a short amount of time (not long enough for heat soak to become a problem)
well lets say they some how managed to fill all the cooling channels with liquid nitrogen, as the engine would heat up a extreme amount of pressure would be exerted to the internals of the engine by the liquid nitrogen trying to become a gas = catastrophic failure = very bad.
the only way it could be implemented is by spraying it in a liquid form in front of the radiators and as it becomes a gas will cool the radiators.
and then there are the safety issues for having that much liquid nitrogen on the track, freezing drivers and the anesthetic effect of nitrogen and the chance of a explosion due to the liquid nitrogen heating up
and then the engineering complications. how are you going 2 pump it what will keep the spray tips from freezing, un even cooling will cause the radiator to crack what if a pipe caring liquid nitrogen broke there would need to be a emergency shut of capable of operating in extreme cold, how to store enough liquid nitrogen and how to keep the insulated vessel crash proof
and the added weight would slow the car down making any cooling benefits negligible
i saw a setup in i think it was an off tits turbo vs commodore a few years ago that had a massive esky in the boot filled with liquid nitrogen and the coolant was passed through a heat exchange in the box to cool it down
If you had liquid nitrogen in your engine and it was still a liquid.. im pretty sure your oil would be frozen, since it has a freezing point somewhere around 0 °C , and the liquid nitrogens boiling boint is something like -195 °C, probably would freeze your fuel aswell ;)
I've been looking at water/methanol injection to keep my intake and internal engine temps down :P
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
