Hey everyone,
I have finally put pictures up on Gallery of my car. I had so many problems getting them to upload, but it's all sweet now.
I suppose it's a GTv because it has HICAS but if anyone else can tell me anything else from the photos, that'd be great. Any hints, comments question would be great.
cheers
Chanz
Edited by slinky-minky
https://www.sau.com.au/forums/topic/331956-new-photos-of-slinkys-skyline/
  • Replies 61
Hey man I have a gt-v myself, check your brakes if the front brakes are the bigger calipers with the nissan logo on them then thats a big sign that it is a gt-v, unless the previous owner has done a break upgrade, also your rear suspension should have the forks at the bottom for mounting rather than the eyes and one more thing to note is your diff, gt-v's have the gtt diffs but i have no idea on how to tell the diff. maybe someone else can help out with that.
Edited by mzahir
dudes i havnt even had the car 3 weeks and have done nothing to it yet so calm the F**K down....... lol
thanks for the advice mzahir and krzysiu
thats not a nice comment GUN_METAL_GTR32, just because its a bit of a sausagefest in here lol
Chantalle
To start off I'm putting a spoiler on it on the weekend, I brought it off one of the girls on the forum.
Also wanting to do some rims, but I'm not in a huge hurry , what would be the ideal size to still keep the same handaling characteristics etc and not nessecitate me to get it lowered? maybe 18's with low profils will lower the car and look better but wont they not fill the gaurds.... hmmmm
noooo 4 doors should be spoiler-less. you'll ruin the flow of your car's lines. please go into the 4 door sedan/taxi section and check out the hot rides thread for ideas.
also if you're gonna rock 4x4 profile suspension don't go big rims, the car will look like some lebo from sydney owns it.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
