Hey all,
Got my stock R33 2IU turbo off the car now. Found it to be in excellent condition, no notable shaftplay! Exhaust wheel has a nice burn on it and front wheel in excellent condition. Comes with the elbow, drain outlet, oil line + bolts, one water line and one cut water line.
Came off my car at 127xxxKM, no idea if its the original though. Replace your blown item or good upgrade for your RB20.
$300
Also have my 3" 1 piece dump and front. Yep the bell mouth job 1 piecer. Mild steel job, usual surface rust.
Seems to be of higher quality than most of the JJR/ebay ones, no grind marks from cleaning up gay welds. Pipe has been properly pressed into the flange and fits VERY well. Fitment is excellent and even bolt clearance was good enough to take it off with the turbo in the car!
$100
OR
$350 for both.
Can also supply with a stock manifold if your looking for some DE+T love, Ill include it in the price for both.
P.S. trades welcome.
Cheers,
Depends on what youve got, PM me and Ill see.
Looking for parts for the R33, upgrade side feed injectors, Z32 afm, that sort of thing.
Cash works too.
Items I am looking for trade:
- R33 front pipe - 70mm ID inlet - 80mm ID outlet. Will trade for my one piece (if you have a front pipe and no dump yet this would be perfect).
- 3" (80mm ID) Cat. Branded etc.
- Sidefeed injectors to suit R33, 6 of them, bigger than stock. Hiflows OK.
- FMIC. Stealth preferred, branded would be best but I will consider a JJR.
- Z32 AFM, dont need the plug.
- Tyres, 245/45 17 or 234/45 17 in pairs.
- R33 castor rods.
- R33 rear camber arms.
- Fuel pump, aftermarket suit R33 intank.
Anything speed related for an ECR33 turbo really. I am willing to cash adjust either way.
PM me.
sorry man got nothing for an r33. However i have one step better on the air flow meter. I have a q45 which is 90mm and good for more HP or rwkw whichever you prefer to use when talking about power
Items still available.
Will swap the turbo for a cooler pipping kit or the 1 piece dump for just a front pipe.
Somewhat negotiable on price.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
