I think i might put a computer in my car soon. I had a brand new power fc but sold it cause i thought i was selling my car but i couldnt part with it. Im kicking myself for doing that, i wish i hadnt of.
Anyway im wondering what available in the way of ECU's for my WGNC34 series 2 neo RS4 Manual S?
https://www.sau.com.au/forums/topic/331976-whats-available-in-ecu-options/
Have a look at www.nistune.com and also search "Nistune" on this and the Skyline sections.
In brief it is a tunable chip that sits in your stock ecu. For under $400 it is unbeatable. You could also fit a PFC, Link, Motec etc etc but the Nistune is by far the best value for money.
Then find a really good tuner (after you have fitted any planned mods) and spend whatever it takes to get a really top tune!
My cars was stock apart from pod filter fmic and no rear mufler and made 200atw on 14 with the nistune. Car had 146atw before the tune. I just got a Garrett 3076 I'm fitting at the moment but now I need injectors exhaust afm fuel pump custom lines etc $$$
i have a nistune and it makes 164 rwkw with hks exhaust and 9 psi and auto..just dont have the funds to get a front mount...200 awkw seams a little overrated with a manual box if its a standard turbo
Just a question, what mods do u guys have and what power are you making? And how much boost can these systems handle?
Nistune
Gt3076 .82 IW
650cc injectors
R34 gtr fuel pump
Exhaust and fmic
245rwkw at 14.6psi (1 Bar)
Hoping to get to 300rwkw with more boost (19-20psi) and tune.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
