  • Replies 54
lol. i only weigh 64kg.
so mid to high 200's with the basic mods that i have? i could run 10psi as i have a r32 actuator kicking about but im just worried about the turbo spitting its impellor fins.. and i dont have the cash to upgrade to a hks turbo. i did a boost run this afternoon an it made exactly 7psi on full throttle with standard 25 actuator in 4th gear with no boost controller or stock boost solenoid, just straight boost to the actuator.
Eat less burgers
lol. i only weigh 64kg....
Eat more burgers
Seriously, whip the spare out, any spare tools. Given the weight of the car and the hp your making it wont make much difference. Fibreglass gurads and hood might help a bit.
This thread is halarious.
The only "practical" things to remove to save a bit of weight (however given that your car is stock I don't see the point as you will notice nothing.)
Spare wheel
Factory jack and tools
Factory floormats
Boot lining
Problem is the rear of the car is not the main area that you want a weight saving. The front is where all the weight is on a R33 and what causes it to understeer, thats the hard area to remove weight from.
Honestly one of the best upgrades weight saving wise on a R33 is replacing the factory bonnet with a lighter carbon item. Good weight saving of 10 odd kg (dependent on quality of bonnet) and you are removing weight from the front. Problem is the legality side of things and the quality of the bonnet.
There are heaps of weight saving oppotunities if safety and legality aint a concern, hence for a track car.
Edited by PM-R33
Easy to remove wieght from front :P
When you say Alloytech do you mean the Alloytech V6 found in Holden Commodores?
If so I don't think that counts for the purposes of this thread :blink:
LOL asked how to get the kilos out , this is how just piss off the 25det junker :D
    • Probably being in IT for 2 decades, and spending my time documenting trees worth of shit and also being on the receiving end has taught me a thing or two.
    • Why's that depressing, wouldn't it be able to go indefinitely until the battery gets old and craps itself? If it's constantly on charge/maintaining charge, won't that keep the battery healthy?
    • One of my concerns initially was if something catches fire somehow.
    • I think I know what you mean. I saw the same thing a while back, I think either the images on the website were wrong or the model was slightly updated. It was weird when I first looked at it, same model but different looking unit.
    • At work we've got a smaller version of the Projecta that Duncan posted above. At home, I have an ALDI trickle charger. Ive had it for about 8 years now. Only issue with it, it's a smart charger, so if the battery is dead, it won't bring it up, but I have a variable power supply that I limit current on, and set to a max of 14.4v. once it starts charging up, I put the aldi unit on and remove the variable PSU. ALDI one will do 12v, or 6v, then has mode for "car" "motorbike", and "snow". With car or motorbike more for its internal workings, and snow is the trickle mode. I have a battery in the garage that lives on this charger for about the last 18 months now on Snow mode. When I need to charge my other batteries (eg, ones that have died in a car), I get them started and then run it on car mode. Voltage is always sitting really nice, and hasn't killed a battery yet. that charger isn't good for things like Lithium batteries etc, I'd only use it on Lead Acid.
