Hey guys,
I have recently converted my R34 GT to a GTT, so basically swapped everything over including engine, gearbox, etc. I had to get a brand new clutch to suit the pull type of the R34 gearbox so I bought a Exedy organic racing clutch.
Now I notice when in neutral and I take my foot off the clutch I can hear a whirring/grinding sort of noise coming from the gearbox/clutch sort of area. Goes away when I put the clutch back in. What could this be? I thought it may be the clutch bearing, but the clutch is brand new?
Thanks for any help,
Martin.
https://www.sau.com.au/forums/topic/332010-whirring-noise/
will be input shaft bearing, very common. All my gearboxes have done it after a couple of clutch dumps, i have never broken a gearbox due to the input shaft bearing being noisy, so its an annoying noise but not a problem
throw out bearing is only in contact and spinning when the clutch pedal is pressed, doing this stops the input shaft spinning so the noise goes away.
https://www.sau.com.au/forums/topic/332010-whirring-noise/#findComment-5386953
So it's not a problem then?
What about this: Sometimes when I don't take off nicely (still getting used to clutch so can't drive it very well yet), so would be riding the clutch a little bit, the clutch sounds like it is knocking against something. Very very audible. I had assumed this was normal being a racing clutch as the clutch would just want to bite on and go, but I have been told that it's definitely not normal? Happens when I'm reversing lots as I don't like to take my foot all the way off the clutch...
https://www.sau.com.au/forums/topic/332010-whirring-noise/#findComment-5387075
thats a weird one, is the noise from the clutch area or back of the car?
never heard of an exedy clutch having problems. but you never know
without hearing the noise in person its a guessing game. so take it to your mechanic or a gearbox specialist and get them to diagnose it.
Did you get the engine and gearbox package from a wreckers? or privately? did it come with warranty?
https://www.sau.com.au/forums/topic/332010-whirring-noise/#findComment-5387358
my exedy cushioned button shuddered a bit on takeoff sometimes, it sounds a bit like quick repetative knocking. Im not sure what the race clutches are like but
Best thing to do if you can is to get a video of it and post it up, so we can all hear whats going on :ermm:
Edited by 89CAL
https://www.sau.com.au/forums/topic/332010-whirring-noise/#findComment-5387405
I'm in the hills mate, in between Midland and Mundaring. Bit far from Bunbury :ermm:
I'll get a clip of the clutch a bit later today. I think the sound is coming from the gearbox/clutch area, but sometimes there is a knocking coming from further back in the car as well. I bought a full R34 GTT donor car from KYP, they did the conversion as well. Will take it back to them on Monday. There is also a shudder/vibration at the friction point of when you take the clutch out, but KYP said that may be because it's a racing clutch and it has started to go away as the clutch has worn in. But I really hope they haven't f**ked something up in there, I can't afford a new clutch :P
Edited by Hanaldo
https://www.sau.com.au/forums/topic/332010-whirring-noise/#findComment-5387559
my friends s15 made the same noise when he has his new organic clutch put in, we took it back to roy at kensai and he told us its because we were not releasing the clutch properly and riding it.
might be different for you but his doesnt make a sound anymore even when i drive it lol
https://www.sau.com.au/forums/topic/332010-whirring-noise/#findComment-5391719
Sounds like the same story as me ^ I've done about 600kms on the clutch now, it hardly ever does it anymore. Wasn't sure if that's because I've gotten used to it and learned how to drive it or if it had stopped doing it ;)
https://www.sau.com.au/forums/topic/332010-whirring-noise/#findComment-5393589
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
