21AZI
Suspension: S13 Front Hubs, S13 Fully Adjustable coilovers all round'
R32 GTR 4pot Front Calipers and GTR rear calipers, 5 std, Front Sway Bar & rear,HICAS removal
Wheels: Front 18x8 with 225/40/18 tyres and Rear 18x9.5 with 285/35/18 tyres
The engine is a R34 RB25 neo.
Modifications: Gearbox 5 speed GTR R32, Chrome-moly flywheel, Brass button clutch, Bosch 040 fuel pump , surge tank, adjustable fuel regulator , Catch can , Apex bov,15" Davies Craig thermo fan, VL Radiator, Turbosmart boost controller, Battery in the boot, front mount intercooler, plenum and 68mm XF body,1 piece tailshaft, hks cam gears,Oil cooler and oil filter relocation, micro tech LT-12, TO4 Turbo 69hks inlet wheel and 0.7 housing exhaust , Tial wast gate, 10l sump (for Oil), head std kit (ARP), mean std kit(ARP), com head gasket, gates timing balt, N1 oil pump and lots more.
Stereo Audio / Visual: it works and T.V
Estimated Power:1st dyno it made 298hp on 7-8psi and then on 12psi the new GTR clutch late go at 5500-6000rpm and it still made 347hp it was back in the year 2001.
Lates Dyno was it Pits on the 10/9/2009
And it still made 270hp on 7psi
310hp on 12psi
350hp on 15psi
And that was the old sit up
Here are some photos of the new R33 diff in my HR31
RB26/30dett Engine Build
Just a little list of parts in the RB26/30DETT
Conrods (Howard)
Pistons(CP)
Oil Pump (Greddy)
Oil Pump Drive Extension
Cam Gears (Greddy)
Camshaft (Tomei)
Spring (Tomei)
Lifters(Tomei)
Retainers(Tomei)
Head studs (Tomei)
Main Studs (ARP)
2mm Valves Inlet & Ex
Ross Balancer
11L Sump
2x GT 35/40
And more
990cc
We see how it go's
https://www.sau.com.au/forums/topic/332032-21azi-shtbox/
  • 1 month later...
Sorry for the shite photo's, It was a loan phone
R33 GTR engine cradle and R33 diff cradle are in my hr31 now. HELL YER
The holes are cut for the front axle's for the AWD.
Just waiting on the RB26/30 to be fitted agian then off the get it painted.
https://www.sau.com.au/forums/topic/332032-21azi-shtbox/#findComment-5457419
  • 5 weeks later...
LOL
If you think the hr31 is get built fast, you should see my rodeo!
The awd drive is all done now on my hr31.
Got a hold up on the hr31 now. as i need to finish off my rodeo first (Who what to buy a cool show Rodeo?)
Cool
(fats)How far off is your HR31 from awd?
Did you put the r32 rear diff in as will?.
On the front rails, did you cut it back about a 100mm for the gtr cradle and did you use a r33 or a r32 cradle?
You got same photo's
love to see how you did it
https://www.sau.com.au/forums/topic/332032-21azi-shtbox/#findComment-5523984
nice work
just sticking my gtr front cradle in my hr31
any more picks
things you would have done diffrently?
and thats a hell of alot of turbos for 800hp
i love it!
Got same more pics
Just have to her to post them up for me.
Done diffrently
I should have done it all 10years ago when I built the car the first time.(Before I boke my Back)
It's hard to whiching people working on your car.(But Jeff is a f**ken Good Guy).
"Hell of alot of turbos for 800hp"
LOL that's on low boost
Who what to buy my injectors They are 990cc. I need to buy same ID2000
Edited by 21AZI
https://www.sau.com.au/forums/topic/332032-21azi-shtbox/#findComment-5524604
  • 1 month later...
  • 3 months later...
  • 7 months later...
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
    • Yeah car has 110 on the clock. That said the front turbo (that exploded) doesn't seem to be the original, it has a S1 part number but the car is a series 3. Yep, in the cat is where I first found the turbine wheel pieces - a couple decent sized ones, then a whole lot of fragments.  I agree, probably makes sense to upgrade parts that are being replaced. Things like rods would be 'nice' but realistically it seems unlikely they would need replacing. I was hoping that it was a case that they generally f**k up the valves but not the bore, or vice versa. Is it generally the scour damage rather than ceramic bits getting mashed into the piston tops / valves? I tried a search but couldn't find any threads with pics from the guts of a motor that's had this happen.
