That's what i like to hear! the bit about it feeling special I mean.
This is a learning curve for me, I dont even own a toolbox, or have my own garage. so that might give you an idea of how often I work on cars.
Pardon me for being ignorant, but if a turbo fails, does it destroy the whole engine with it? whats the worse case scenario regarding turbo failure?
Mine had stock turbos when I bought it, and ran upto 20psi for a year (very sure they were not stock..) the front one blew, so pulled them out and stuck some N1s in there, also know of an R32 that has done Targa Tas about 9-10 times now running ceramic turbos, and has not had 1 turbo failure. My suggestion would be if you like working on cars, and are happy to have it off the road a bit, (and spend some money) then push the limit a bit, try to do the work first though (be it Turbos, or even an R33 motor etc). If you are not wanting to do this sort of work, do not run over 10-12psi, and keep plenty of oil in it (1/2-3/4 litre over full) and you will have a reliable (if thirsty) and very fun road car. After 1 year my car still feels special every time I drive it, and I love it.
  • Replies 49
I have 2 of the same car. I love both. I drive my wife's car over the weekend and then the GTR on Monday and it is heaven. Worst case you will lose an engine. $10k bill for a proper fix.
Turbo's shouldnt fail at 14psi or under.
I can't see a reason they would unless its been thrashed to hell, which I doubt would be the case.... (with this car anyway)
If its stock, check for the boost restrictor. My 33 still had it in there, 14 years down the track. Taking it out = 14psi. (Was in place to help make it "276hp")
Edited by Ten Four
I've gotta say, I couldn't have found a more helpful forum, really appreciate the feedback and answers to my many questions from you all!
There's still a chance I may pull the pin on the whole idea and wait a bit longer, but it's been an interesting few days learning the ins and outs
of buying a GTR.
Thanks guys.
You might be right about that. As far as I can tell
though, the only difference is Brembo breaks, BBS wheels, a sticker on the
back, and an updated 4x4 system? I think they're also a tad heavier?
Haha, I'd go that VspecII if the Vin and car checks out.
Value will only go up :)
Yeah, Brembo's, BBS, sticker, different diff, R33 GTR 4wd system (its much quicker to shift torque to front wheels).
Some said steel compressor wheels in the turbos? I'm not sure on this though.
Plus, only about 1300 VspecIIs ever made.
Ok guys,
I've decided to not go ahead with either of these cars for now. Thank you all for your input, I probably would have made a huge mistake
if not for this forum.
The dream is not over! but I need more time to look and research, its foolish of me to think I can find an original car that wont need money spent
on it, so I hear what you're all saying about the pros of buying an already modified car, its just a matter of finding one that's been modified in all the
right areas with an emphasis on durability and reliability - for me anyway.
Cheers,
Paul.
V-Spec II = Base model R32 GTR, but with:
Brembo Calipers.
Revised ATTESA E-TS system.
17" BBS wheels with 245/45/17 tires.
Weight about 50kgs more.
Standard Ceramic Turbo's as only the R32 GTR N1's came with N1 Turbo's = Steel Wheels.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
